CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
DVD burner will play but not burn
By fishbrain on Nov 07, 2007
I recently built my first computer and everything was smooth. Now I'm having problems with my DVD burner. I have a brand new Lite On LH-20A1S model drive. Before this one I had a brand new LG GSA-H62NK. Both drives will read and play dvds but won't burn them. I also have a DVD CD/RW drive that works perfectly plays dvds and music and burns music. The two drives that I'm having trouble with are both SATA while the other drive that works is a IDE drive. I'm thinking that may have something to do with the problem but I can't find anything in the BIOS that looks like it would have an effect.
When I attempt to burn a DVD with Nero 7 or 8 "tried both" the process starts and it will stay on 1% for about 15 minutes then it comes up and says
generating high compatibility borders
successful generating high compatibility borders
then it says burn process failed at 18x.
I'm running Windows XP Pro SP2, AMD Athlon 4000+ Processor 2.41 Ghz, 1GB ram, DFI nF4 Ultra-D MoBo.
Any help would be greatly appreciated, thanks in advance.
Same Problem
Feb 05, 2009
-   I have a Matshita UJ-850D Internal DVD drive as well as a LG External DVD drive both will play CD/DVD record only CD have tried uninstalling and re-installing drivers but it didn't work. Any other suggestions would be appreciated -   jvidro584
Sep 16, 2008
-   I have a DVD BURNER Hewlett Packard. It will burn cd's ok & play dvds ok l but when i go to burn to DVD it only goes to 1% some times it will go higher e.g 37% But freeze before burn completes. What is the best way to resolve this problem and what could be the cause of this problem
Kind regards
Scott-   zepher78
Aug 06, 2008
-   DVD will play but not burn or copy. I've tried both NERO and SONIC with no luck.-   Guest
Aug 04, 2008
-   i have a usb toshiba cd\dvd burner i can burn cd's view dvd but can no longer burn dvds it all worked a week ago no new software installed.-   squatking666
May 09, 2008
-   SONY DVD Burn process faild at 18x (24930KB/s) im using XP-   Guest
Solution #1
posted on Nov 07, 2007
Somewhat Helpful)
latinmcgyver
Rank: Guru
Rating: 86%, 201 votes
in device manager... remove ide controllers.. all of them.
reboot an it reinstalls automatic then retry..
also make sure burner is master on ide and reader is slave... if not try burner by itself as master and see what happens. there was a bug of xp and intel sata sometimes writing then it was blank.. slaved burner on secondary when sata present or something to that point.
Was this helpful?
Yes
No
Solution #2
posted on May 31, 2009
Not Rated)
engr_bolanos
Rank: Apprentice
Rating: 0%, 0 votes
try this... i hope this one works...
1. Go to registry
2. Link: HKEY_LOCAL_MACHINES/SYSTEM/CurrentControlSet/Control/Class/{4D36E965-E325-11CE-BFC1-08002BE10318}
3. Check if there is LowerFilters
4. If there is none, create a Multi String Value and name it "LowerFilters"
5. Right click on it then choose "Modify"
6. Put in "PxHelp20"
7. Close the registry and restart the computer
Please Let Me Know If It Helped Otherwise I Will Try To Look For Some More Information To Help You...
or E-Mail Me...
engr_bolanos007@yahoo.com.ph
Was this helpful?
Yes
No
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD... (More)
Answer
my cd burner only burns about 2/3 of of the songs from i tunes
Answer
i just installed a 22 internal super multi dvd writer. cant install software , because i have nero 7... (More)
6 Other Users Have The Same Problem - Continued
Comment by touqeer, posted on Dec 02, 2007
i am not able to copy movies
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CD and DVD Burners:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14909
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
