Question about Creda W100FW Front Load Washer
Where is the filter ?
I have a creda w100fw and cannot find the filter, help !
  • Creda Master
  • 3,463 Answers
Remove lower rear panel locate and remove large black hose at bottom right of washer, and clean filter ionside hose
Please rate my solution.
Thanks.
Posted on Aug 10, 2009
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Where is the filter
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Feb 10, 2009 | Creda W100FW Front Load Washer
Where is filter
Filter is located in the large black hose attached to bottom of drum, remove hose and clean filter.
Access is by removing lower rear panel of washer.
Plz leave feed back for this solution.Thabnks.
Dec 18, 2008 | Creda W100FW Front Load Washer
Creda W100FW will not take the powder from dispencer and stops during wash
check water supply is on, also you can get low pressure which can cause this problem you could try tablets. and poss your brushes are worn out
Mar 02, 2008 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
282 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
