Question about Samsung Microwave Ovens
What does SE on my microwave clock ad mean?
What does SE on my microwave clock pad mean?
  • William Miller
    William Miller May 11, 2010
    -SE- error on a Samsung model means you
    have a shorted membrane keypad. But please note that for some GE models, the membrane keypad is not
    available as a separate part, so you would have to order the control
    panel frame which comes with a new keypad. In this case, you simply
    move your circuit board into the new frame. That is a simple do-it-yourself job. Please reply back with your brand and model number so we can help you.
  • Rosanne Mckenney Nov 20, 2011
    What is the part needed to replace (on a Samsung microwave SMH8165) to fix a shorted membrane keypad.
4 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: The microwave display shows "--SE--" I have not
SE error indicates a short in the keypad assembly. This will mean the the control panel or smart board will need to be replace.
Microwaves are not good do-it-yourself projects. Microwaves are extremely dangerous to work on even while unplugged. Even unplugged some components retain a lethal amount of voltage.
Here is a link for the website and contact technician: Sears Home Services .
Hope helps.
Posted on Jun 11, 2011
billinghurst
This fixed mine.
The problem lies with the mylar ribbon cable that connects the Keypad to the circuit board. The Mylar ribbon cable folds back onto itself and are touching. Over time the mylar 'breaks down' electrically and the wire traces in the mylar will 'arc' onto the other mylar ribbon cable. The solution is to separate the two mylar ribbon cables using paper and electrical tape. I've done this on several microwaves (not just Samsung) and it has worked every time. Patience and about 20 minutes is all it should take to fix it. I've described below how I did it for the SMH9187ST Microwave Good luck to all.
1. UNPLUG THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2) screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch (there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad Housing (phillips). Lift the Keypad Housing upwards about half an inch (there are tabs holding the Keypad Housing in place) and remove. Be careful of the metal grille that is just above the Keypad Housing as this may fall out since it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses that are attached to the Housing. Carefully unplug the wiring harness that has the RED connector on it from the circuit board. Carefully unplug the small white connector that has the mylar ribbon cable on it (this cable is see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit board onto the Housing.
7. The Housing should now be free of the circuit board and wiring harnesses. It's safe to let the wiring harness/circuit board hang free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing. There are (4) plastic tabs holding the frame in place. Using a small screw driver pry one side of the frame away from the housing (try to do this to the side that has smaller plastic tabs). When this side of the frame is free of the Housing you have to lift the frame out at an angle to remove. It might put up a fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the mylar ribbon cable that is coming out from underneath the Keypad assembly. You will notice that the mylar ribbon cable folds back onto itself as it re-enters the Keypad assembly. This 'touching of the two ribbon cables' is where the trouble lies. The ribbon cables may be stuck together. Carefully separate these two and then insert a small piece of paper between them (paper can be 1/2 x 1/2 ) and work the paper all the way down into the Keypad assembly as far as it will go.
10. 8. Using electrical tape, apply a small piece between the ribbon cables to hold the paper in place. Next, use more electrical tape and put it between the mylar ribbon cables enough so as to keep the ribbon cables separated.
11. 9. Re-attached the thin metal frame making sure to press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw metal edge of the thin metal frame to prevent the mylar ribbon cables from rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful when inserting the ribbon cable connector back on to the circuit board. The connector is loose and you need to gently place the ribbon cable into the circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset and ask you to set the time.
16. Hope this works for you !!
Posted on Oct 24, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: S-E on pad
"SE" means you have a shorting membrane keypad.
If I knew the full model number of your oven, I could give you advice.
Feel free to ask here.
Posted on Sep 06, 2012
Need help with se error
"SE" error on a Samsung Microwave Oven means that the touch-pad membrane is faulty and needs to be replaced.
Jan 01, 2017 | Microwave Ovens
-se- is displayed on the screen, what does it mean?
Usually means "Sensor error". The problem is usually associated with the circuit board for your touch pad on the front of microwave. More than likely a bad contact/connection on one of the plugs in the back of that panel.
Just type the following in your search engine and the video explains it all. "samsung microwave se (5e) error fix". Hope this is your fix and that you are OK with taking it apart. MAKE SURE ALL POWER IS REMOVED BEFORE GETTING IN THERE!! good luck!
Oct 08, 2015 | Samsung Microwave Ovens
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
S-E on pad
Sep 05, 2012 | Maytag MMV5207A Microwave Oven
I have the SE code on my Samsung microwave. I have replaced the touch pad but the code remains. Any further advice? What is the purpose of the second tail on the pad; not the one that goes into the plug...
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement, if it has already been replaced then it is better to replace the ribbon cable connecting the board. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | Samsung MW1080STA Microwave Oven
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
Aug 31, 2010 | Microwave Ovens
Goes to military time
According to the manual:
Press "Clock" pad once to set clock for 12 hour time clock
and
Press "Clock" pad twice to set the time for Military time.
I'm not sure what you mean by "goes to" military time.
Is that after you've already set it for a 12 hour time clock?
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
1,553 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
