Question about Whirlpool Duet GHW9150P Front Load Washer
Spin cyle problem
Washer is not spinning the clothes to damp, then after you take clothes out it fills with water again even though its off
  • 31 Answers
It sounds like you have a blockage some were around your pump best thing to do is try and unblock it
Posted on Jun 28, 2009
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Mar 23, 2010 | Kenmore 43142 Front Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
CANDY CM1612 WASHING MACHINE
dose the drum spin at all please clarify eric
Jan 04, 2018 | Maytag MAH6500 Neptune Front Loading...
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Standing water after the spin cycle
it could be a faulty water inlet valve]Is water going overnight ,ie. when machine is not in use.?
Dec 20, 2007 | Maytag SAV5710 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
145 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
