Question about Motorola Mobility V170
I washed it!
I have now washed my 3rd V170. Rather than buying a brand new one, is there any way to fix this last one ... new battery, new SIM, or is it just a lost cause? Thank you for any help.
Not necessarily a lost cause!!! Open it up by taking out battery and all screws. Carefully pull out insides and gently dry out everything inside, electronics, etc. using a blow dryer on low setting. Put it all back together and give it another try. This has worked on a couple phones I've dropped in water. Won't always work, depends on whether or not phone shorted while it was powered on. good luck. This also works well on tv remotes that have been spilled on. They almost always clean up well and work!
Posted on Nov 07, 2007
  • 316 Answers
Sorry to say its a lost cause
How to sim card unlock a tracfone v170
you can unlock it and switch over to another network , if you want to unlock, you can get codes here
you need to specify the country and network provider
Nov 10, 2010 | Motorola Mobility TracFone® V170 Cellular...
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
I have a tracphone motorola V170. The flip door broke. Can I buy a new motorola phone not a v170 and transfer the sim card?
Ah, I am a former tracfone customer, and the v170 phone was my first model. :) . Unfortunately no, because all of tracfone's phone models use a different sim card, even if you attempted to replace the sim card with an identical phone it would not work, the phone simply reads, UNREGISTERED SIM CARD. Its tracfone's way of making money, so unfortunately you'll have to put in your contacts all by hand :( which is a major pain in the rear.
Jun 17, 2010 | Motorola Mobility TracFone® V170 Cellular...
I have a Motorola W260G Tracfone and I'm getting a "Restricted Number - 34" message all of a sudden. What is this about?
Had a similar problem on my V170. Remove the battery and the sim card. Using a q-tip dampened (not dripping wet) with rubbing alcohol, clean the metallic side of the sim card and allow to air-dry, then wipe once more with a dry q-tip. Do the same for the metal terminals in the sim card slot if visible. Go ahead and clean the battery's contacts and the ones in the phone while you're there. Put it all back together and try again. This will fix most sim-card problems as long as there's no physical damage.
Good Luck
Aug 03, 2009 | Motorola Mobility TracFone® V170 Cellular...
Invalid battery
The battery is probaly no longer capable of holding a charge, you can get a replacment Motorola V170 battery here - Motorola V170 battery
Apr 13, 2009 | Motorola Mobility V170
Absolutely, what you need to do first though, is have your IMEI and SIM serial numbers handy from the first phone. Simply push the center, round button in the middle of the top array, and it should open to Prepaid, select that and go to the 2cd option which is IMEI and select that, and write down that number. Then do the same thing with the 3rd option, which is SIM. Once you have those 2 numbers in hand, do the same ith your new phone. Once done, call the 1 800 number for your area and speak with a represenative and they will walk you through the rest of the proscess and add your existing minutes to your new phone.
Mar 13, 2009 | Motorola Mobility TracFone® V170 Cellular...
My vodafone simcard
i need a master code for my tracfone for the security code
Nov 06, 2008 | Motorola Mobility TracFone® V170 Cellular...
Re: Motorola v170 I need to get it off trac fone
Purchase an AT&T SIM Card and activate it
May 23, 2008 | Motorola Mobility V170
Phonebook says "try later"
The only thing I've found that helps is to proceed as if direct dialing. Enter (1) digit then end. You can then get to your phone book etc. I've had (2) V170 and had the same issue with both.
Aug 28, 2007 | Motorola Mobility V170
Motorola Mobility V170 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
