Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Top freezes but bottum doesnt cool - Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
  • 672 Answers
The fan has quit working or is blocked. The fan is usually located in the back of the freezer, under a cover. this is easily changed if you have access to parts and a few tools, you can probably replace it yourself. Unplug frig while removing fan and the cover, remove the fan attaching screws, unplug the wire, reverse sequence for installation. It is safe to leave the frig plugged in while you get replacement fan. Whirpool makes Kenmore so you may be able to get the fan at Sears parts center.
Posted on Jun 28, 2009
NOT GETTING COLD
the ptc overload/relay on the compressor side as this part is bad and will no longer start the compressor to cool the unit
Aug 12, 2012 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
I keep pouring out anitfreeze. i let it cool top
no it doesnt corode it, its all in what GM recommends, If you're blowing through anti freeze, I would check for a leak or maybe replace your thermostat.
Dec 19, 2009 | 1998 GMC Jimmy
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
Window goes to far down and doesnt stop
Sounds like either the stoppers fell out, or you will need to readjust the track. You will have to remove door panel and visually inspect track and slider. Should be stops at bottom of slide rails
May 13, 2009 | 1999 Porsche Boxster
Loosing fluid on top rear of engine.
check your hoses where the heater core comes out of. If the clamps are old replace them. Check around your intake manafold and your heads. Check your dipstick for a milky substance at the bottum of the stick. Is your thermostat in the rear of the engine. Check this too. Also if you just replaced any freeze plugs check all of them even the ones you just replaced. They may not be in correctly.
tepfy
Feb 27, 2009 | 1998 Ford F150 Regular Cab
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Dec 19, 2007 | Freezers
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
133 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
