Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
My Acer Aspire M1640 was working fine then all of a sudden it won't "connect" to the monitor. Only displays "No Signal". Shows NOTHING at start up. Doesn't make the BEEP it used to at start up. Check another monitor does same thing..... nothing. Changed out cords to monitor no luck. Opened computer but I honestly don't know what anything is. There was 2 large cards in slots... I removed and replaced to make sure secure. Still nothing. HELP! I need the Acer computer for work!
  • 4 more comments
  • michigang876 Jun 28, 2009
    I get nothing.... just "No Signal"
    What do I clean the contacts & slots with? To "blow the dust" what should I use? We have TONS of dust (live in the ciountry on a dirt road) and there is dust all over the back of one of the fans. Literally chunks of dust! Thanks!
    Well... I will try the dusting. Yes, it is on a powersurge.... a good one. I have read a lot about the video card coming loose? Where is that to check? Also, if it is the motherboard.... is that an end all to the system? To replace usually how much in cost? The computer is less than a year old and I treat it well.... with the exception of the dust. Would it help to connect it to the HDMI instead of the VDA connection? Thanks for everyone's help!
    Did the dusting thing... no luck.
    Any other ideas? Please? Is there any chance the HDMI cable would work as opposed to the VDA? And how can I locate the video card?
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi, When you first turn the computer do you get a post/splash screen?
  • Acer Master
  • 4,806 Answers
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
Posted on Jun 28, 2009
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Jun 28, 2009
    What you need is vacuum cleaner with a pipe attachment and a soft, clean, dry paintbrush.
    Remove the powercord from the back of the PC.
    Start by removing the ram and clean the contacts with the brush, turn the vacuum on and gently brush the dusty components including the fans, the CPU fan, the metal heat sink under the CPU fan and the bottom of the case, as your removing the dust place the nozzle of the attachment near to the area your cleaning make sure you touch the nozzle on any of the components, pay particular attention to the memory slots.
    When your done reseat the memory and the power supply and try to boot again.
    Good luck
  • Lee Hodgson
    Sorry DON'T touch any components with the nozzle.
  • Lee Hodgson
    If the machine is under a year old have you thought of taking advantage of the warranty and send it in for repair?
    President:
  • 948 Answers
Your computer isn't functioning then. If you have reseated all the cards you can but you "honestly don't know what anything is" you have done all you can and it is time to take the computer to a shop for testing. You have a bad component somewhere, power supply, video card, memory, or motherboard. The only other thing you can try on your own is blowing all dust from the system. Are you using a UPS/surge protector? Have you had any recent electrical surges?
  • Dick
    Dick Jun 28, 2009
    You blow it with compressed air. You can buy it at any office supply place, Best Buy, Office Max, Office Depot. It's not likely to fix your problem but you could get lucky and it is cheap to try. http://www.wisegeek.com/what-is-canned-a...
  • Dick
    Dick Jun 28, 2009
    I suggest premium support if you want more time spent searching for an answer.
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
My acer aspire m1640 crashed and now when i turn it on nothing happens the monitor says no signal
Sound like a bad motherboard.You are getting the error because no signal is been sent to the monitor. Make sure the memory is inserted properly and firmly. Check all other cards and plugs are all inserted and firmly sitted. and try to boot the system, if nothing stll happen, you may have a bad motherboard
Apr 12, 2011 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire M1640 has no signal to monitor ? I try to star up with out the ram card , I can hear the beep .. Any idea what is the problem ? Thanks.
I have the same problem, i have tried everything and some people say its because the graphics chip on the motherboard has burnt out due to improper cpu pasting
Jan 15, 2011 | Acer Aspire M1640 Refurbished Intel...
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
I made various test:
cpu (pentiun e2180) pass the test mounted on another PC.
I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
Some of this Acer model have this motherboard crash
look also here
http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
Change the MotheBoard
Mar 10, 2010 | Acer Aspire M1640 Refurbished Intel...
We have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Aug 23, 2009 | Acer Aspire M1640 Refurbished Intel...
Low volume in acer x193w
install the audio drives again then it will worl fine
Jun 25, 2009 | Acer Aspire 5100 Notebook
Monitor freezing and screen crackling.
Sounds to me like your graphics processor is overheating, or possibly the cpu. Are any of these components new? you may want to make sure that they have proper cooling. On the other hand if its a few years old, may jus need to replace the overheating component.
Mar 15, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
1,269 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
