Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
My 4 button will not work all the time, what can I do?
You can set it at 390 instead of 400, if that dosn't solve it then you may need to fix it.
This is what the guy in the appliance dept. at Sears told me. He said he has been doing this
for many years.
You can't beat going to the experts for this type of advice.
Posted on Jul 03, 2009
How do i get my clock off military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem
Nov 06, 2016 | Audio Players & Recorders
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
My GTB3410 sometimes the three buttons below the touch is not working alternatively, some times call button is not working at the same the back and end button is working , some times end button is not...
unscrew your phone and remove the keypad. then try pressing the phone without the keypad, if it works very well it means you will have to buy another keypad for your phone.
May 12, 2011 | Cell Phones
Ink absorber full, ip2600
I have a ip2600 that has had the waste ink absorber msg come up twice. After trying several recommended fixes involving pressing the Resume key twice then 4 times, etc., I've found the perfect solution. Start by cleaning the waste pads with tweezers, etc.
1. Press Power Off
2. Disconnect Power Cord
3. At SAME TIME, Press & HOLD Power Key while re-connecting Power cord
4. Release the Power button
5. Press the power button again
This will work!
Nov 18, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Moved the mirco wave, then the only buttons that work now are the time set, but it only shows 12hr and 24 hr, and will not set the time. none of the buttons will work now for the cook time. if the power...
i cant work out if its broken or not over the years i do remember seeing a sanyo microwave that would not cook untill the time was set though have not seen another since (cause its a silly idea) but try setting the time and it might work
Oct 14, 2010 | Daewoo KOR-860A Microwave Oven
TWO KEY FOB IS NOT WORKING ONLY ONE
Have all keys with you inside the car and repeat again with the second key within 30 seconds...... "Press and hold the 'unlock' button while at the same time pressing the center 'lock' button three times. On the third time, release the 'lock' button at the same time you release the 'unlock' button." If you have a key with three buttons, ensure doors are unlocked. Put key in ignition and turn key over to 2d position where dash lights, etc come on. Pull key out. Press and hold the "unlock" button while at the same time pressing the center "lock" button three times. On the third time, release the "lock" button at the same time you release the "unlock" button
May 20, 2009 | 2003 Mini Cooper
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
Canon iP2000 waste ink absorber
You dont replace it, you wash it and reinstall it in the printer. Use hot water for washing it.
resetting the waste-ink full code:
1 - press resume button and then press power button
2 - realese the resume button and press 2 more times then realese both
3 - press and release resume 4 times and power 2 times...
The way it works is to PRESS the ON/OFF button plus the RESUME button at the same time, keep your fingers on both bottons all the time THEN let go of the resume button and press it 2 times and only then let go of the OFF/ON button (which you have been helding down while pressing the resume button 2 times). Then INDIVIDUALLY, first press and release the resume button 4 times and the power button 2 times after this. Works like a charm !
Feb 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Scanner not working
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Nov 05, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Vcr will not work
Try pressing down the vcr or Aux button for a long time. Then try pressing down power button on remote for a long time. Try info or display button for long time. After I fiddled around with these for a long time it worked.
Sep 29, 2007 | RCA VR355 VHS VCR
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
64 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
