Question about Pioneer DEH-1800 CD Player
If antenna is not connected will it turn on
Installed all of my wires right and fuses are fine but antenna cable isn't long enough to reach. but she wont come on. could the antenna not being connected make it not turn on
    Novelist:
  • 108 Answers
Definitely double check the ground connection on the installation (Black Wire). Also verify that you have constant 12V+ (Yellow Wire) and accessory 12V+ (Red Wire) at your radio connection. The antenna will not be needed for the radio to power up and many automotive parts stores or stereo shops will sell antenna extension cables anywhere from 1 foot to 18 feet in length.
Posted on Aug 04, 2009
    Sergeant:
  • 227 Answers
The unit should power up without an antenna. If it powers up then you would only get hash noise on the speakers. You can put a paper clip with a 12" piece of wire to the input or where the ant should go to see if you are getting a signal.
If you have power at the unit then you may have a bad ground (-).
Mike
Posted on Jun 28, 2009
Sony DVD/VHS player to my TCL Roku TV
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sep 15, 2016 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
Antenna
The only reason to have an electrical wire going to the antenna is for a motor that raises and lowers the antenna. The antenna cable to the radio is the only wire on the antenna.
To replace the antenna, you have to remove it from where it connects onto the car, then lift it out from there. The antenna and the cable cannot be separated, it's all one piece. You pull the cable off of the back of radio, and tie a strong string onto it, because when you lift out the antenna, the cable will be pulled out from under the dash and to wherever the antenna is situated and out that hole. Now tie the string onto (hope you had a long string, lol) the end of the cable on your new antenna and cable, and stick the end of the cable into the antenna mounting hole. Pull the string from under the dash by the radio and you will bring the cable back into the dash and where you can plug it into the old radio and listen to good old music again !
Feb 13, 2013 | Suzuki Alto Cars & Trucks
Wiring short
see if all wires are connected tightly...battery,starter alternator. also see if any wires look melted or burned. if all that is fine then maybe a voltage regulator (if it has one)
Sep 15, 2012 | 1991 Ford Thunderbird
The white, black & red wires located behind the face of the CD (the eject cartridge) broke away from the terminals on the small circuit board. What is the wire(s) orientation so I can reattach them? ...
Hello
I will give you a full rundown on how to install the cd changer;
Disconnect the car battery.
Run the cable from the Jensen changer to the back of your dashboard. Depending where you mount the changer, you might want to hide the cable under the carpet or run it along the door panel. Take some time before you mount the changer to figure out what is the best way to run the cable for your situation.
Remove your deck and the dashboard around it to access the back of the deck.
Locate the antenna lead plugged in to the back of your deck. Unplug it.
Find a good space to mount the FM modulator behind the dash and close enough to the deck to connect the antenna lead. You can secure the modulator to the inside of your dash by using two sided Velcro tape and place it where you need. Plug the antenna lead into the modulator's "Antenna In."
Connect the FM modulator to your deck by plugging the "Antenna Out" lead off the modulator to the antenna in on your deck.
Connect the two power cables from the modulator to your car's power. One lead goes to a constant source of power and one connects to a switched 12-volt power source.
Ground the modulator by running the black wire to an exposed screw. Wrap the wire around the screw and tighten it down so the wire doesn't come loose.
Reinstall your deck and dashboard.
Find a spot on your dash to mount the display unit. You can get creative and cut a hole in your dash and mount it that way or you can use Velcro tape and place it on your dash that way. Make sure it is close enough to the driver's seat so it can be accessed without having to reach too far. If there are loose wires hanging from under the dash you will want to tuck them under the dash and wrap them with wire ties.
Sep 12, 2011 | Jensen CH1001 10-Disc CD Changer
It appears the polarities on my original 2008 yamaha r1 battery are not correct is this common. I removed it and put it on a battery tender. The red hot wire only reaches the negative connector on...
If the cables fit fine before you removed it and now don't, either you are putting the wrong battery back in....or you need to turn the battery around so the terminals are close to their proper cables.
Never reverse the cable connections,
Apr 02, 2011 | 2008 Yamaha YZF-R1
Antenna MOTER KEEPS RUNNING DRAINS BATTERY CANT FIND HOW IO DISCONNECT IT. WHEN I TAKE OUT FUSE IT DISCONNECTS HORN EXT
If you can reach the motor simply disconnect the wires. Cap the wire ends to prevent a short.
Jun 13, 2010 | 1992 Buick Century
I just installed a Pioneer DEH-P4200UB in my wife's car. It was working fine last night after I wired the harness. I pulled the dash today to install it... I snugged it up, then reached in to connect the...
If it is nothing but static on the tuner that means that the blue wire on the harness which hooks up to the one originally coming from the car is not hooked up to the blue or blue/white from the pioneer. Or you yanked on the antenna so hard that it disconnected from a connection point in the car.
Also write the make and model and the year.
Apr 04, 2010 | Car Audio & Video
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
May 14, 2009 | Alpine Car Audio & Video
Extending the Antenna wire to reach new deck
If it is a Chevy then the antenna wire will not fit in the first place. best buy sells an adapter that ill extend that wire and make it the right size. The wire is like 7 to 10 dollars.
Apr 14, 2008 | Kenwood KDC-MP235 CD Player
AMP turns ON then turns off
The power antenna wire only supplies 12vdc when the radio is on. When CD or other sources are selected, the power antenna wire goes to 0vdc. The remote turn-on wire provides 12vdc whenever the head-unit is on. If your amps are powered on only when the radio is turned on, I would bet that you have the power antenna wire connected and not the remote turnon wire.
Sep 11, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Pioneer DEH-1800 CD Player Logo
141 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
