Question about Pioneer DEQ-9200 3-Band Car Equalizer
DEQ 9200 does nothing but blink
I have installed the deq 9200 and followed the instructions but the only thing it will do is blink like the power goes on and off. I have checked the connections and cleaned the contacts and still nothing..where did I go wrong.
1999 mustang gt alpine head unit, deq9200, 2 punch 500's and 1 punch 50. only thing used from factory was power wire and remote wire.
Check DEQ "back up" battery wire (orange color), use multi meter to measure the voltage. If voltage are unstable then you must re-wiring the back up battery wire, link and loop it to your alpine player back up wire (yellow color). If it still same problem happening, then sent your "DEQ-9200 hide-away unit" to nearest Pioneer ASD. Change itside P.C.B. back up power battery (black color, 5.5volt -beside system control IC) and clean up the battery leaking part.
Posted on Jul 13, 2009
  • 578 Answers
Check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Posted on Jul 07, 2009
My head unit resets settings when key is taken out
Do you have the yellow wire going to a constant 12v power source? The yellow wire controls the memory of the radio and needs to have 12v going to it at all times, even when the key is taken out of the ignition.
Jun 28, 2012 | Pioneer DEQ-9200 3-Band Car Equalizer
Upon installing deq 9200....a humming sound exist as i pedal my gasoline
Check your ground wires. Power and audio need to be ran on opposite sides of the vehicle. Try re grounding the radio the a new location. make sure all grounds are connected to bare metal.
Feb 17, 2011 | Pioneer DEQ-9200 Universal Audio Processor
My pioneer deq 7600 keep resetting it wont memory
do you have the yellow wire going to a constant power source??
Sep 24, 2010 | Pioneer DEQ-7600 15-Band Car Equalizer
DEQ DIAGNOSTIC TROUBLE CODE P0300 - MISFIRE - OREGON DEQ
first is up you octane with an adative or tank of has. the next would be to inspect your rotor cap for crac ks/ scale build up. if showing a lot of build up on the contacts replace cap and rotor button. Those ate the easiest and cheapest improvements. the octane boost reduces the misfire due to detonation
Oct 02, 2017 | 1999 Pontiac Grand Prix
I have a deq-9200 one day it just shut off, I've tried everything, fuses , etc.i dismounted the central part (not the display) and noticed there was a liquid that leaked. Any suggestions?
Check the capacitors near the leak source if they vent ie swell on top then it is possible they have split causing fluid leakage they will not be far from leak on pcb replace the ones that look swelled
Jan 06, 2010 | Pioneer DEQ-9200 3-Band Car Equalizer
I have a Pioneer DEQ-9200 DSP Audio Processor
are your power wires and your rcas on oppsite sides this may be your problem
Oct 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
My pioneer deq-9200 equilizer keeps resetting to default settings whenever i start my engine. What's going on here?
The EQ has two power wires on the back like a head unit. One is constant power, and the other one is ignition/switched power. This normally happens when the installer takes the switched power and applies it to both power leads going into the EQ or head unit. The EQ needs the constant power line run to a 12V source that never turns off. The constant power line is normally yellow, and the switched power line is normally red.
May 19, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Pioneer DEQ-9200 3-Band Car Equalizer Logo
377 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
