I emailed Brother and they gave me the following response. It was so fast they have clearly been ask it many times. I've not tested it yet, but could be worth you giving it a try.
You can lessen the amount of time but not remove it completely.
Press Menu, *, 2, 8, 6, 4. to go into 'maintenance' mode.
Press 1, 0 and WSQW00 will appear to the display.
Press 2, 4 and WSW24 = (an 8 digit number).
Use the right arrow to go to the third digit and type 1.
Use the right arrow to go to the fourth digit and type 1.
Press the Stop button.
Press 9, 9 to return to the main menu.
Rerecord your OGM without any delay.
Solution for Fax1360, if this does not work please let me know as this process should be the same.
Recording an outgoing message (OGM) on an external TAD 7
Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
b Limit your speaking to 20 seconds.
c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
Christy
The machine picks up and beeps as if waiting for a fax tone, then there is a lnog pause before the OGM plays. During this delay, the majority of callers hang up and fail to leave a message
