Question about Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore top loading washing machine is leaking from the bottom. The water is dripping from the bottom of the front panel. What needs to be fixed and how do I do it?
  • 1,170 Answers
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Posted on Jul 11, 2009
2 Suggested Answers
  • 1937 Answers
SOURCE: i have a top load kenmore washing machine and it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on May 09, 2010
I have a Kenmore top load washing machine and it is dripping water inside. Do i need to replace a valve or a gasket?
Until you find out why it is dripping turn off the water behind the washer. Then I would go and search online typing in the browser search "Kenmore top load washing machine model no _____ leaking - what is causing this?" and hit enter. You will get lots of leads. I did a quick search just on Kenmore top load washer leaking and found this video.
Hope it helps.
Tami
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 03, 2015 | Kenmore Washing Machines
1 gallon of water leaks out the bottom (overflow?) dripper with every load.
your pump seals are bad,this is a cover to keep the pump dry if something up above leaked,but from the pics it looks to be the pump especially with all the water leaking,just replace the pump unit
May 04, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front loading washer model # 417.43042200 is leaking Hi, I am finding water on the floor after I wash several loads of laundry in a row. My husband took off the bottom front panel and we found...
Could be from the pump shaft seal. If so you need to fit a new pump/Also check not door boot seal is ripped or overfill from powder drawer too much water pressure...
Jan 31, 2011 | Washing Machines
My Kenmore front loading washer machine is leaking. I open the front bottom panel and watched it during a washing. It seams to be leaking from the bottom of where the to halves of the tub(?) come together....
Hopefully its leaking somewhere else and just running down and dripping off the seam between the two halfs. If the seal between the two tub halfs is actually leaking you would have to completely dissassemble the unit very BIG job. Maybe take off the top lid and watch it operate hopefully you will find the leak up top...Good Luck
Sep 07, 2010 | Washing Machines
Hi, our kenmore elite washer model 110 front loade...
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$$$
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
Elite 45986 Front Load Washer: My 2002 Kenmore elite front load washer (stackable...
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Aug 25, 2009 | Kenmore 24032\24036 Top Load Washer
Small leak/drip at on the front side of the washer..
possibly water pump you need to get fix asap cause it could start fire!!! Good Luck!!!!
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaking
check your water valve at back and your water connection.if there o k it probably is your pump.
Nov 12, 2007 | Kenmore 22422 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
866 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
