Question about Philips Magnavox Learning Universal Remote
I have a signature 2000 color tv that does fine once it is turned on but a few seconds later it loses the color on the screen. When I use the remote control it shows volume level and channel secection in color. Can you help?
SOURCE: i need a code for my remote control
i need the code for sony model kv-36s500
Posted on Jan 16, 2008
SOURCE: Remote Control Programming
Ihave magnovac tv. and found the old remote control. but I do not have the code. Please help
Posted on May 28, 2008
leecom72
  • 4806 Answers
SOURCE: TV won't work with any remote control
you have to reprogramme the remote, here is the offical site with instuctions and codes for your device:
http://www.universal-remote.net/philipsmagnavox.html
regards and dont forget to rate us!!!!!
Posted on Nov 27, 2008
  • 34 Answers
Try here
Hope this helps!
-Curtis
Rate my solution please!
Posted on Feb 01, 2009
  • 686 Answers
SOURCE: tv codes for signature 2000 using philips universal remote m4355
0031 0000 0001 0023
Posted on Feb 18, 2009
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
My tv just changes colors when I turn it on with no picture, no of the buttons work on the remote or tv, what is the problem
Your TV is in the service mode. Just try one of two things to correct this. With the original remote, press the cursor button left, followed by pressing the right cursor button. Now shut the TV off. When you power up your TV it should be fine. The second thing to try is to press the cursor button up, followed by pressing the cursor button down. Power off the TV. Now power it up and it should be fine. Thanks for asking and show a few hands of support.
Jan 03, 2011 | Emerson Televison & Video
Emerson LC320EMX LCD color patterns
Did you find a solution, I have the same problem with my Emerson TV. Same color pattern loop. Tech support was no help and TV is just 3 months out of warranty.
Jul 13, 2010 | Televison & Video
Samsung DLP HL-R5067 blinking lights
when is the wheel is broken doo you cleaned the glass around because if it not rotate tv not turning on it is a one of the posibilitis
Mar 02, 2017 | Samsung Televison & Video
Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Philips Magnavox Learning Universal Remote Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
