Question about Office Depot Office Equipment & Supplies
I have a Staples Mailmate Shredder and all of a sudden the power light doesn't come on so it won't shred. The bin is empty. Is there a reset button somewhere?
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
SOURCE: mailmate by staples shredder won't turn on
I took my Mailmate back to Staples and exchanged it for the model that took it's place. It's been working great. Since it was still under warranty when I took it back, it didn't cost me anything extra. SteveChen, I never got to try your solution but I salute you for having the determination to fix it yourself! From what they told me at Staples, the upgrade has eliminated the power problem. Apparently, the last model was just plain crappy as is evident in the number of people in various forums who have had the same problem. I'm keeping my fingers crossed that the new model is indeed free of power issues!
Posted on Jan 03, 2009
SOURCE: No power to Staples mailmate
There is a 10mm 5amp @ 250v fuse on the main board that is probally blown . I unsoldered mine and soldered a pigtail fuse holder with a convient sized 5 amp fuse inside in its place . The shredder is not too bad to take apart , the head comes apart from the body of the shredder .Turn it upside down and you will see 6 or 7 phillips screws .Once these are removed the head assembly opens up and you will see the circuit board which is held in place by 2 phillips screws. A quick ohm meter test will reveal the fuse condition. It was an easy fix just MAKE SURE YOU KEEP THE UNIT UNPOWERED while you work on it or its unassembled.
Posted on Jul 18, 2009
  • 3230 Answers
SOURCE: Staples Mailmate Shredder do not
First of all you try plunging them in to other power board, check the cable and the plug (check if the cable or plug not getting shorted), make sure the circuit breaker for the shredder outlet is on.
tell me is there any humming noise? or any sign of power getting in to it?
Please post back further comments for more information...
Thanks
Posted on Sep 07, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
I recently bought a Staples Shredder Model #SPL-TXC152A & has worked fine up until now. I emptied the bin as I have previously & bow shredder will not turn on.
There is a bin interlock switch that has to be closed for the shredder to shred. If the shredder mechanism is separate, look for a slot on the underside.
Apr 13, 2018 | Staples Office Equipment & Supplies
Shredder is jammed
Disassemble it enough top expose the shredding mechanism, then remove all material that is jamming it.
May 27, 2016 | Staples M5 Mailmate Shredder
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Mailmate by staples shredder won't shred
drive is seized-remove power cord- open cover rotate cutting drum slowly using motor drive gears - look for debris/gear teeth missing
Mar 02, 2014 | Office Equipment & Supplies
Rexel rsx1227
The sensor may be blocked with shredded paper.
Oct 24, 2013 | Staples SPL638X (CrossCut) Shredder
Staples mailmate shredder bin won't open
The bin may be overfilled, preventing the latch from releasing.
Mar 28, 2012 | Office Equipment & Supplies
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
Jun 24, 2009 | Office Equipment & Supplies
Mailmate by staples shredder won't turn on
I took my mailmate out into the driveway. got in my truck and ran over it two or three times. it doesn't work any better but I feel great.
Oct 25, 2008 | Office Equipment & Supplies
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
424 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
