SOURCE: PIXMA mini260 ERROR MESSAGE:U140. THE
hi!!!!
try to unset your cartridge and place it correctly!!!!
or clean up the cartridge socket
SOURCE: Error U140 & U071 for Cannon pixma mp800
Thanks for checking back my printer problem. Solved the problem--purchased a new printer.My big problem now is repairs on my Mitsubishi WD 52725. I do not think I will buy a new one of those.I will purchase your help package for help with that. Please advise.
Cosie
SOURCE: Error U071 or U140
check in bottom of the ink cartidge u must have to remove plastic
strip.then also check u proper fixed ink cartridge in ink tank as
matching color.
re-seating the cartridge may temporarily fix the problem but it will not last. but if even that doesnt give u relief.... then its a hardware failure and wud service is required at this point. contact Hp...
thank you for using Fixya...
have a nice day
SOURCE: I have PIXMA MX860, I
The ink tank is not compatible with this machine. (The lamp on the ink tank is off.) You can try reseat the cartridge if that doesn't work, you need to replace it.
Here's instruction on how to replace an ink cartridge for MX860 http://support-au.canon.com.au/contents/AU/EN/8200407400.html
