This code indicates an elevator motor Ascent/Descent Failure. Most commonly this is caused by one or more of the trays in your finisher not being fully inserted into it's "slot". Check the output bin trays at the far left side of your machine on the finisher. Be absolutely sure they are fully installed into their holders. Then turn off then back on the MAIN power switch in order to reset the code. Watch the bins. They should raise and lower and the code should be gone. If it comes right back and the bins are where they are suppose to be then you have another issue with the sensors or the elevator motor and will need service.
Most everytime I see this code it is always the trays are not all the way in.
Here is the info from the service manual in case your are the techy type.
Good Luck and Thank You for using Fixya. We are having a contest this month for customer testimonials. If I have helped you with your free question today please take a moment to leave a testimonial.
10.2.1 C1183: Elevator Motor Ascent/Descent Drive Failure
Code Description Detection Timing
Relevant Electrical Parts
Elevator Motor (M11-FN)
Elevator Tray Home Position Sensor (PC3-FN)
Elevator Tray Lower Limit Sensor (PC14-FN)
Top Face Detection Sensor (PC15-FN)
Elevator Board (PWB-B FN)
Main Control Board (PWB-A FN)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical Component)
Check the M11-FN connector for proper
connection and correct as necessary.
Check M11-FN for proper drive coupling
If OT-601 is connected, check the connector
for proper connection, and correct
as necessary.
Check the installation position of the
OT-601 tray, and correct as necessary.
5
Check the setting of the adjusting plate
for the Exit Tray detection position and
6 M11-FN operation check PWB-A FN PJ7A FN-1 to 2 FS-508 G-7
7 PC3-FN I/O check PWB-A FN PJ12A FN-2 (ON) FS-508 G-4
8 PC14-FN I/O check PWB-B FN PJ2B FN-3 (ON) FS-508 H-6
9 PC15-FN I/O check PWB-B FN PJ2B FN-6 (ON) FS-508 H-6
10 Change PWB-B FN - -
11 Change PWB-A FN
