Question about Kenmore Elite Oasis 27052 Top Load Washer
F1 error message wash cycles and rinse cycles
After starting machine regardless of cycle before i can walk away the f1 error comes up and beeps. I then stop it and re-start it, sometimes I end up changing cycle or temp until I hit on one that will take. Then when it gets to rinse...same thing. I end up stopping it and just use rinse....2nd rinse will stop it
Any clues
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
I keep getting an F1 error code on my whirlpool elite washer at beginning of cycle and at beginning of rinse cycle, why?
F1 error code usually refers to a control board or touch pad failure in a whirlpool washer.
Hope this helps if you have any further questions message me back Thanks Rick
Jul 17, 2011 | Washing Machines
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Heavy Duty 80 Series Extra Capacity Plus Model# 92480200. The washer will begin to fill and will not stop filling regardless if water level setting is on low, medium or high and will overflow and...
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 30, 2010 | Kenmore Washing Machines
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
F1 error code
replace machine control bd under console
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
