ILO SDTV. Just started getting white message on a black screen: Digital Channel Signal Strength is Low.
  • 69 Answers
Digital is plaged with poor coverage areas
you may need a taller ant
Posted on Jun 28, 2009
My screen shows this message.... "Digital channel signal strength is low." what do I do?
buy one of those 15 or 20 dollars amplifier to step up the signal. Radio Shack is gone. Try the internet.
Feb 14, 2018 | Televison & Video
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
Insignia NS-30HTV 30 screen is black on all inputs, and says digital channel signal strength is low, can i fix this?
you need to get a digital aerial first .then you can sort out any other problems from there
Oct 03, 2012 | Insignia NS-30HTV 30" TV
Sansui HDLCD1908B Television
call you digital cable provider
Jul 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
Sanyo mod dp19241-no pic 'Digital channel signal strength is low' is on screen
Hello
As the set reports, the strength of the digital signal it gets may be weak. An other possibility is the fault with its digital tuner itself. Check the digital signas strength first. You can contact your cable provider, and ask them to check the signal strength at your premises's cable end. If it found satisfactory, there is no other way than replacing the digital tuner of your TV.
It is a skilled work, and should be done either by any expereinced serivce technician or by the authorised service center for Sanyo at your town. OK.
Oct 23, 2011 | Televison & Video
26" ILO digital T.V . won't pick up digital signals w/digital antanae.\r\nusing air in setup
So called digital antennas are generally a gimmick. The important factor to receiving stations is the antenna position and strength relative to the incoming signal. (Digital signals are either enough for the tuner or you get "no signal".)
Look at antennaweb.org or tvfool.com to find out what stations are likely to be received in your area and the direction to rotate the antenna; plug your address in the search area. Antennaweb is very conservative in its channel list even though it assumes an external antenna. Tvfool gives a list of the channels you should get with various antennas (labelled by color). This is a standard label that will be on the antenna specs or box (at least on good antennas). Tall buildings and trees in the area can reduce the channels you receive.
Adding an amplifier may help you gain signal strength for borderline stations (or if you split the signal to several devices).
I hope this helps.
(My house has an external antenna with an amplifier/splitter. Antennaweb suggested that we'd only get the stations from ~10 miles away. We get those stations and the ones from ~30 miles away with the antenna rotated for the further stations.)
Sep 11, 2010 | iLO 2600 Television
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Need to make my ilo sdtv become my monitor for my laptop.
hey,dude you need the right chip ask comp for the master chip 45
Mar 28, 2009 | Toshiba 26HL84 26 in. HD-Ready LCD...
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
Televison & Video Logo
257 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
