TV worked fine the last time used. Now when I turn it on it makes the usual 'click' sound, the green LED lamp indicator comes on (as it usually does when powering on) for about 1 second, then the TV turns off.
Assuming it was the lamp I replaced the bulb with the one I had previously removed from the set and stored for just such an emergency (replaced previous bulb because I had to replace a damaged screen and the bulb was a few years old, not because bulb was burned out. Prevention is better than repair). The problem persists. Any ideas would be appreciated.
Comments:
Jun 30, 2009
- Yes, tried this first.
Jun 30, 2009
- No, the TV turns itself off too quickly for this to happen.
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Comments:
Jul 02, 2009
- Any luck checking the color wheel? I can help you through the dismantle if you're stuck. A quick and easy way to partially check the color wheel is to pull the lamp housing and look straight into the compartment that the lamp shines into. You'll see about half of a golfball sized glass wheel. If you can see any missing pieces of the 'pie', you've found your problem. If not, it may be on the other side you can't see. With the lamp removed, bypass the lamp door switch and power on the TV, watch to see if the color wheel moves or not. If not, you may need to do some surgery. The wheel on this set is an older model. The glass is held in place by a pressure plate. The glass tends to slip out over time and either lodges itself in the plastic housing and stops the wheel from spinning, or breaks and sets off the motor sensor. I've seen more than one of these wheels broken and if you're lucky, as was the case of the last one I worked on, the glass had just slipped out. with a carefull push and some high quality super glue, the color wheel was as good as new.
The other culprit could be the ballast. It is the 3 x 8 (ish) circuit board that the lamp wires hook into. Its also on the optics block tray. These are trickier to diagnose but are cheaper to replace. Give it a thorough look over, look for any burst or crowned capacitors and any tell tale signs of shorting. When dealing with the ballast please be aware that the large capacitors on this board carry enough punch to do more than enough damage to send you to the hospital. I am not kidding. So if/when you do inspect it make sure the TV has been disconnected from the wall at least over night. Even then be carefull as you handle it. This should give you a better start on your repairs. I may be able to further assist in the dismantle if you're not comfortable doing it cold turkey. Feel free to email me directly if you'd like. Cfoley@hawaii.rr.com
Jul 02, 2009
- Two more quick things. The lamp door switch may not be the only switch you have to bypass to get the tv to spin the wheel. There may be another similar switch the senses wether the lamp housing is in place. It should look relatively the same and shouldn't be too hard to locate.
Second, when you're looking at the color wheel throught the housing access. It will be very obvious which part is the color wheel. Its, yep you guessed it, a three color glass wheel.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Samsung HLN617W 61 in. Rear
Samsung HLN617W 61 in. Rear Projection HDTV Television
My Samsung HLN617W developed several problems recently. 1) I'll be watching a station, attempt to...
(More)
My Samsung HLN617W developed several problems recently. 1) I'll be watching a station, attempt to switch to a different station and the picture changes. The top 3/4 becomes scrunched up and unformatted to the widescreen picture and the lower 1/4 is a green color. 2) If I attempt to turn off the TV with either the remote or manually push the button on the set, nothing happens and the entire screen slowly fades to a bright green. 3) I may try to turn off the set while watching TV and it simply won't turn off. I have to then unplug the cord manually. On the flip side, I may try to turn it on but it won't. I have to unplug and plug the power several times to get it to start. All of these problems recently developed and work intermittently with one another.
Samsung HLN617W 61 in. Rear Projection HDTV. Left side of screen has 4 inch section from top to...
(More)
Samsung HLN617W 61 in. Rear Projection HDTV. Left side of screen has 4 inch section from top to bottom where the screen is darker than rest of tv. How do it fix this?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
