Question about Panasonic CT-32HXC43 32" TV
Panasonic tv - no power
I cannot get anything from my panasonic 32 inch flat screen hd tv.....the model is ct32hxc43g.......
  • 2 more comments
  • sfitch Nov 18, 2007
    This is the second problem I'm having with this TV. The picture is wider than the screen. Sounds like a simple adjustment. It's been in the shop for 4+ mos..The problem is either the yolk or the board. The tech. is trying to save me money by isolating the problem. We are looking for another set just like it to help diagnose the problem.
    Does your TV come on for a split second and then shut off. If not, try unplugging it and turning off your cable box. Plug back in and turn on box. Try the TV again. My would start to turn on, then shut itself off. My TV repairman was able to fix that problem.
  • Pretzelboy Dec 18, 2007
    My Panasonic CT-32HXC43 has been no problem for 4 years and we had it on today three separate times now I come home and it has no power like it is not pluggged in.
    What's the story??????
    Mark in Hanover, PA
  • ShowDogDad Jan 27, 2008
    My Panasonic TV was working this morning just fine. Came back home 2 hrs later, and it wouldn't turn on. Any ideas?
jeffreyirish
  • 7 Answers
SOURCE: The TV Will Not Turn On
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Posted on Jun 18, 2009
  • 236 Answers
SOURCE: Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Posted on Feb 12, 2007
geemarie
  • 876 Answers
SOURCE: Problems with 50 inch flat screen Panasonic
Yes there is a way to work with formatting your Tv. On your controller go to menu and settings and look for display. you can change where the words display. Bring them up or down. The lines, I'm not sure about. are all your connections nice and tight?
Posted on Jul 31, 2008
SOURCE: panasonic ct 32sl14 flat screen tv
you need a dtv converter for the free broadcast signals. make sure to get $40 rebate card from gov't.
Posted on Aug 12, 2008
SOURCE: Panasonic 32'' TV wont power on
I just received the same model from a neighbour because it too wouldn't power on after suddenly quitting. The T.V. rrepair shops quoted $160.00 to $250.00 to fix the power supply/transformer. All I did was rremove the back and check if the circuit board was actually receiving power from the corsd - it wasn't. I then replaced the plug, plugged it back in and the set works prefectly now. This is a commonm problem with panasonic and certainly does not require the services of a technician, not the exorbatant costs quoted to repair. Simply cut off the plug and replace with a sturdy self sealing/connecting one available at any hardware store for less than $1.00.
Posted on Mar 16, 2009
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Troubleshooting 32 inch Philips LCD TV
Sounds like a power supply problem that typically is caused by a power surge of some sort. Check with tvrepairkit. com for their power supply kit to do the repair yourself.
Jun 19, 2012 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
The HD-TV screen stays on for 4 seconds then it
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 10, 2010 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Astar 32 inch flat screen model LTV 32BG
The only way to salvage the TV will be by repairing the power supply to the component level, meaning you will have change the parts that failed on your power supply.
Is a common failure on power supplies modules.
Let me know if you need further assistance.
Jun 10, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
32 inch lcd tv screen smashed
WRITE IT OFF YOUR COST FOR THE SCREEN ALONE WILL PROBOBLY EXCEED THE COST OF THE TV
Jan 13, 2008 | LG 32LX1 32 in. HD-Ready LCD Television
Panasonic CT-32HXC43 32" TV Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
