Question about Frigidaire FES367 Electric Kitchen Range
Blackened pans, high flames in oven even at 200 degrees
When i turn on the baker the flames come form underneeth up the sides of the oven, the top sides and food are black with sooth the food itself is not burned, but the top of my cakes are black
  • 2 more comments
  • angelbarton Jun 28, 2009
    since I bought the stove
  • angelbarton Jun 29, 2009
    I think there has to be some adjustments made to the oven but I don't know where,!! help
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    You only answered one of my 3 questions.
    Has this been happening since you got the range, and how are the top burners working? Are you on LP gas?
  • 1,543 Answers
You still have not answered the questions I asked you, and you have posted your question under an electric range model. I will just have to guess and give you general info due to the lack of information you have given.
I will guess that you are using your range on LP gas. You don't compain of top burner performance, so I will take that to signify that the regulator has been changed from natural to LP, and that the burner orifices have been changed as well. That leaves only the oven. You need to find the spot where the gas comes out of the safety valve and travels up the venturi tube to the oven burner. There will be a small (about 3/4 inch square) adjustable air flow hole there, and right there you will see a brass collar. Use a 1/2 inch wrench to turn that brass collar three full turns clockwise. (it is usually easier to count 12 one quarter turns) If someone has tried to do this step, it may be part way turned in already, so you may not need to, or be able to, turn it three full turns. You do not want to turn it too far, but it will take a little effort. If flames are still too high, turn it a little more. Usually, the square air hole should be left all the way open.
Posted on Jun 30, 2009
Can I adjust the regulator to lower the flame?
Hello Douglas;
My name is Peter. I am a retired field service appliance technician.
What bothers me is that changing these components increased your flame size?
1.) Make sure you have the correct gas safety valve. These valves are preset to inches of water column.
2.) The ignitor has nothing to do with your flame size. What happens is the oven thermocouple controls your oven temperature. When your oven get about 40 degrees above the set temperature, the ignitor and controlling gas components will shut down. When your oven temperature falls below the set temperature the ignitor and gas components will turn back on. There are ovens called accurate, which are expensive and do not have a 80 degree swing.
3.) Ok. Gas regulator. It is adjustable. Generally you have about a 7" water column pressure going into the regulator and 1" to 4" water column pressure coming out.
At the top of the gas regulator you have a long stem. Inside this stem is a shaft with a spring at the top and a valve at the bottom. In between is a rubber diagram which controls the valve based on the gas inlet and outlet pressure.
4.) Adjust. Turn the gas supply off to the range. Turn on the oven and gas burners to bleed the gas from the system.
There is a slot at the top of the stem. With a flat head screw driver, turn the stem top 1/8 of a turn counter clockwise to reduce the regulator outlet pressure. Turn the gas supply back on to check the flame. You may have to repeat this process to get your desired flame.
BE PATIENT. BE SAFE.
Mar 03, 2016 | Frigidaire Kitchen Ranges
What are some tips to ensure successful baking with silicone pans?
Notable Tips for Successful Baking
  • Follow manufacturer's maximum heat ratings.
  • Pans are hot to touch while in the oven but cool down quickly; use hot pads to remove them.
  • Using a cookie sheet underneath will provide stability even for smaller pans.
  • Always use a metal baker's sheet or specially designed sled or rack underneath wider or larger silicone pans.
  • Wash pans thoroughly before first use.
  • Warranties tend to vary with bakeware brands.
  • Do not use knives or sharp objects - they could damage your pans.
  • Never use on an open flame or on stovetop burners.
  • (http://housewares.about.com)
Apr 10, 2013 | Home
Tappan oven is heating up way past where the temperature is set. I even set it to 200 degrees. It goes up back 375 and still kicks in the heat up!
Sounds like a defective thermostat, look inside the oven for a sensor. It should hang from the oven top or high up on either side attached to a little clip. Looks like a metal thermometer.  If it is missing or damaged that would explain the problem and must be replaced.
Jan 31, 2010 | Tappan TGF657 Gas Kitchen Range
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Gas stove causing soot on everything
all of the burners are set to rich...open the vents on the burners more.  If this doesn't help you need smaller nozzles.
Mar 26, 2009 | Whirlpool Gold GW399LXU Gas Range
Yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Mar 13, 2009 | GE Kitchen Ranges
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Too hot
Hi, not sure if you ever received a reply, but there is a setting known as "bypass" on commercial thermostats, if you took the cover off to replace it, you can access this screw, it is part of the body of the thermostat, either to the left or the right of the knob shaft, usually has a "B" stamped, or molded into the body. What this setting does is when the thermostat reaches temperature, it would normally close, shutting off the supply to the burner, thus the temp would begin to fall, by the time it opened back up, the temp would have fallen too much, causing a large temp swing. The bypass setting opens or shuts a passage that "bypasses" the thermostat main valve, keeping just a little burner, making the swing, or fluctuation smaller. So, you probably have a setting too big, causing your bypass flame to be too big, raising, or keeping the temp too high, try turning it in (cw) to lower it slightly, a small turn makes a huge difference, so go easy. Hope that helps, and thank you.
May 08, 2008 | Bakers Pride Y-600 Gas Single Oven
GE gas stove XL44
I have the same exact problem with my XL44, any ideas? Time to buy a new stove? If I do, no more GE for me!
Sep 21, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FES367 Electric Kitchen Range Logo
159 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
