Question about Kodak Easyshare M753 Digital Camera
My Kodak EasyShare M753 wont turn on at all, but when i tried charging it, it still wouldnt turn on. I have tried lots of different charging methods, like my USD port that came with the camera and my printing docking system and it still dosn't work. I have thought about buying a new battery do you think that this will solve the problem and get my camera working again.
    President:
  • 2,761 Answers
This problem is frequently due to corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
I have a Kodak EasyShare Share M753. We've had it for about 5 years. My problem is the screen is dark but has a leaf type object on the screen even when not turned on. It's still there when I
Hello Charles, On a Kodak this age it is not going to be worth having repaired. The cost will exceed the price of a replacement camera, sorry.
Best Regards, Russell
Dec 19, 2012 | Kodak Easyshare M753 Digital Camera
Do you leave camera on as it is charging through computer for the Kodak Easyshare M753 Camera?
Hi it dont need to be on whilst charging, some cameras will switch themselves on when you plug them into the computer, but you can still turn it off, now you need to bare in mind that unless you are using a powered usb port is one that plugs into the mains then into your computer you may have problems charging the camera enough through the computers own usb port, it may still charge so you will have to try some cameras will just power up enough to enable you to transfer pictures onto your computer.
give it a try and see how you get on, it wont matter if the camera is on or off whilst plugged into computer how ever it will charge quicker with the camera off if it will even charge at all
Jul 17, 2010 | Kodak Easyshare M753 Digital Camera
Just won't power up! Tryed the battery from my sam
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 27, 2009 | Kodak Easyshare M753 Digital Camera
Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Oct 16, 2009 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 is not charging.
You LI-Ion battery is bad and not holding a charge. Buy a new one.
Apr 08, 2009 | Kodak Easyshare M753 Digital Camera
Can not charge my kodak i think its my usb cable.
If trying to charge using USB through a computer, you have to have the computer on, booted up, and running! The only other thing to try if that is not the problem is to replace the USB line you use, checking plug ends for damage. Good Luck!
Dec 16, 2008 | Kodak Easyshare M753 Digital Camera
Cant get camera kodak m753 to charge
It appears that your problem lies with the main board their are two small fuses on the main board that can cause this problem. changing the main board is most likey your best bet repair on this can be around 65.00 and up depending on where you get it fixed.
Dec 02, 2008 | Kodak Easyshare M753 Digital Camera
Camera wont turn on
Clean battery contacts. Use "small" flat had screw driver, and pry up "GENTLY" on battery contacts. Replace battery. Hit a few times with knuckle "NOT HARD" next to lens. Turn camera on. Camera will work forever.
Aug 28, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
809 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
