Question about Mitsubishi WD-65731 65" HDTV
Which input is used to plug in from satelitte box?
  • 36 Answers
Doesn't matter. Just pick one and make sure you turn on the one you picked when you want to watch satellite.
Posted on Aug 24, 2009
Sharp tv was set up with satelitte- now no signal with freeview box - do i have to reset tv?
Have you changed the input setting on the TV to match up with the input port you have plugged the freeview box into on the back of your TV?
Mar 02, 2015 | Sharp Televison & Video
I can not record from the pc screen on tv to vhs i can the normal channels but not the pc screen why?
If you have "Cable or Satelitte" your VCR may be hooked to a secondary output from that box not the output of the TV, most TV's do not have an Audio and Video output. This would be one reason why you could not record a PC input
Feb 04, 2013 | Televison & Video
Invalid format
If you get that across all inputs or channels then your digital board is bad. If you get it only on one input such as HD cable box, HD satelitte receiver or Blu_Ray player then they are set for the wrong output on that connector. The TV most likely will only accept up to 720p or 1080i....
May 19, 2010 | Olevia LT32HVE 32 in. LCD Television
I need to know how to setup LG TV to satelitte tv. the model is LG 42Q30 plasma
The best way is to connect the Component (YUV) from your Satelitte receiver to the YUV input of your TV. Then, run the Red and White audio cables as well.
Dec 30, 2009 | LG Televison & Video
Unable to receive local channels
According to the manual for the 42LC2D it should be able to receive local channels through a normal analogue antenna connected to the anntenna/cable coax input connector. You can get the manual here http://us.lge.com/download/product/file/1000001586/60PC1D-UE.pdf
Apr 18, 2009 | LG 42LC2D 42 in. LCD HDTV
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Go from the output of the satelite to the vcr/dvd input and from the dvd/vcr output to plasma set.
Mar 06, 2009 | Panasonic Televison & Video
I can't hook up the vcr
I would strongly suggest connecting a plain, coaxial cable wire from your sat box to the the ANT IN of the VCR. then use another coaxial to run from the ANT OUT of the VCR to the TV. Then you can change your TV to channel 3 or 4 as appropriate.
If you have a newer digital satellite receiver, this setup may not work. In that case, use two sets of red/white/yellow cables - 1 set will run from the out of the satellite receiver to the audio, video IN of the VCR. The second set will run from the audio and video OUT of the VCR to your TV. Then change your television to Aux 1, aux2 or whatever channel that corresponds to the red/white yellow.
Have fun!
-Tha Mp3 Doctor
Dec 31, 2008 | Emerson EWV603 VHS VCR
Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Jan 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture problem when changing channels
Are you using a cable box or a satelitte reciever? If so i would suspect them first. If not, unplug the TV for 2 minutes and try again.
Feb 09, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-65731 65" HDTV Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
