Question about Frigidaire FDL25P1 Dehumidifier
DH runs but does not condense any water out of the air (bucket is dry). This unit was working well until a week or so ago when we had a lot of T-storms and humidity rose considerably. We went from having to dump the bucket every 3 days or so to having to dump it twice a day. Filter has been cleaned with not improvement. Unit is located in a basement room (our office) that also contains a sump pump for the septic system, and computers.The unit is less than a year old.
  • 332 Answers
There are coils in the unit that the water folws across, you can take the filter out and clean the coils, this would help,but even though it is only 1 year old it can go bad,, if it is clean inside and everything is appering to be working it might have just gone bad and n eed a new one
Posted on Jun 30, 2009
1 1/2 year old machine runs but does not pull water from air
is the condenser getting cold at all? if not or only a little, you have a compressor issue. possibly no refrigerant. also check the air flow. if the fan isn't on, it'll just get too hot and water won't condense on heat.
Feb 21, 2014 | Dehumidifiers
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Water is leaking out .At first i thought the tank had developed a leak but no, somehow the water is not getting into the tank .Is there something i need to clean? It was working great until this started...
More than likely, the tubing the drains the water to the water collection bucket is clogged. To solve this problem, turn the unit OFF and unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helped you to solve the problem and thanks for choosing FixYa.
Sep 20, 2011 | Eva-Dry EDV1100 Petite Mini-Dehumidifier...
I purchased this dehumidifier three years ago. It has been working fine up until about two weeks ago. I have the humidity setting at 40%. It is located in my basement which is not very damp. It now runs...
Jeanne, unless your unit is what's called a "Low Temperature" unit (these are designed for basement application) , that may be the problem. In addition, the air intake filter may need to be removed & cleaned.
If yours is not a Low Temp model, raising it up of the floor onto a sturdy table or counter top that can handle the weight of the unit and a full bucket of water, may solve the problem. The reason for this is in a basement, the air temp at floor level is colder than at shoulder level. Non Low temp units struggle to operate at temperatures below 65 degrees. Raising the unit up off the floor onto a sturdy table or counter top, that is strong enough to handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
I hope this information helped you and thanks for choosing FixYa.
Sep 14, 2011 | Kenmore 54501 Dehumidifier
DE' Longhi Dehumidifier - Model: DH=25 - Water does not empty into bucket.
If you're saying the dehumidifier is not extracting moisture from the air?
There are 5 basic, yet solvable reason for this. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a manual unit, turn
the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you to troubleshoot and solve the problem.
Jul 14, 2011 | DeLonghi DH-25G Dehumidifier
HI, I bought a AD50USV gold dehumidifier at Canadian Tire 2 years ago. Last weekend when I went down to my basement there was water around the machine on my carpet! It was leaking but I cannot find the...
What has happened is the the tubing that fills the bucket is clogged. To solve this, first turn the unit OFF & Unplug it. Then, remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jul 13, 2011 | Whirlpool AD50USS Dehumidifier
The humidifier runs but no water condensate found in the warter bucket for one week.
Joshia, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, set the humidity extraction level on Maximum
level
in basement applications . Raising the unit up off the floor,
problem.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jul 06, 2011 | LG LHD45EL Dehumidifier
I have a Goldstar 305 unit and have been very happy with it for 4 or 5 years. Three days ago I noticed it was running very loudly and for much longer than it usually takes to fill the bucket. The bucket...
The problem you're having sound like the drain tubing to the bucket is partially clogged. But, it is resolvable. Here's what you'll need to do.
Turn the unit OFF & unplug it from the wall. Remove the bucket and at the inside top of the bucket holder, you will see a hole or a tube that drains water into the bucket.
Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in the drain hole or tube. Carefully insert the Zip Tie and work it in, until you reach a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or your run out of usable Zip Tie. Then, slowly remove the Zip Tie while rotating (twisting) it. This will dislodge any clogs. Once you start nearing the end of the inserted tip, be prepared for some water to follow.
After completing the above, reinstall the bucket, making sure that it fits "squarely" from top to bottom into the bucket holder. The bottom should not tilt down at all. Plug the unit in, and turn ON the Master ON/OFF Switch. Lower the humidity extraction level to 32 -35%. If you don't have an LED screen on your control panel, set the manual control to Maximum.
One other thing that you want to do on a regular basis. That's remove and clean the air intake filter, if necessary. Be sure to turn the unit OFF and unplug it, before removing the filter.
Jun 29, 2011 | Goldstar DH304 Dehumidifier
HDN455 worked fine last fall. Turned off for winter. Started this week. Sounds and runs fine but not a drop of water condenses. Coils are not frosted over. Unit is warm along bottom. Air discharge is at...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 19, 2011 | Haier HDN455 Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifiers Logo
227 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
