Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite 4t
F & H flashes and the washer stops cycle.
I had the control panel replace but it stills flashes F & H
  • 1 more comment
  • Anonymous Nov 07, 2007
    We found out the flowmeter had quit working. Thanks watugot.
  • upstate May 03, 2008
    Same problem: washer stops, flashes F and H. Water flow and drainage are both normal. Appears to be a control board error.
  • heathloretta Jul 12, 2008
    My washer keeps stopping, & flashing H F, what's up with that?
  • 290 Answers
This what to check for F/H code from repair manual.
If the water is coming into machine, make sure drain hose is only sticking into drain pipe about 6 inches. Post back if you have any questions.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then
valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
detected 10.5 gallons of water passing through it, but has not detected the pressure
switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Posted on Nov 07, 2007
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    Just wanted to follow up on your washer and see what you found or if you have any questions.
    Thanks/Mike
Why the control locked is on , i have a kenmore elite HE 4t washer can't do nothing to make it go away so won't let me make a wash
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 10, 2010 | Kenmore Elite 45986 Front Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 4t. Controls are locked! Tried unppluging still the "controls locked". ARGHH! What to do???
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Keep in mind, control panel features can differ between models. However, the instructions on how to lock/unlock the control panel are printed on the front panel of these washers and are printed in the owner's manual.
If these prelimiary measures do not work, you may have a more serious problem than a simple operator intervention.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite smartwash HE 4T control lock
The following link explains how to correct a Control Lock problem for your washer:
Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Aug 14, 2009 | Washing Machines
HE 2plus washer won't turn on
is it not draining. more than likely you need to clean your pump catch. take the bottom panel off you will see the catch untwist. lots and lots of water is going to come out be prepared
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Feb 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 4t
Try the diagnostic test by pressing Drain/Spin button then press the Prewash button four time within five seconds. It will start to ignitiate the sequence for the inlet valve. The cold then hot then wash  then drain then spin. Hope this will clear the brain of the machine and you are good to go.
F&H means you have a drain clogged, or bad pump or bad inlet valve or pressure switch or the worst ccu.
Oct 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
299 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
