Question about Sony Playstation 3 (PS3) Console
Need to replace battery cover on remote control
How to open battery compartment on TV remote
Two main types of battery cover, if there is a finger / thumb indent then it is press down and push towards end of remote, the other sort has a little ctch at 1 end that needs pusing before the cover will come off, A finger nail is normally enough to do this. Hope this helps
Jan 12, 2016 | Televison & Video
How to remove back cover on remote control to replace battery
Most remotes are a push / slide to remove battery cover. Look for a finger sized indentation on back, press on this and push . Some have a catch that you need to pull towards the rest of the cover, it will be pretty small 8mm or 1/4" , the cover should lift off as you release this catch. Sorry but can't help more , but hope this helps
Jan 01, 2016 | Televison & Video
Just bought Topfield TRF2100, screen on and says"installation", but remote won't work.
Be sure there are fresh batteries in the remote. Be sure they are installed correctly and that there is nothing covering the remote's battery contacts. Look to see if there is a film covering the remote's infrared lens or the receiving unit's eye. Check your manual to see if you need to program the remote to the unit. if it's a multi-unit remote, be sure that you have set it to control the specific unit you're working with.
Jul 17, 2015 | Televison & Video
How do I open the remote control to replace batteries for this 5304476181 remote?
Turn the remote upside down. On the bottom (end away from the front), there is a small cover and the cover has a small tab on one side. Squeeze the tab and pull the battery tray out. The replacement battery is a CR2025. Put the new battery in with the + sign facing up (exposed). Reinsert the battery tray and push all the way in until it clicks.
May 22, 2013 | Sears Parts Direct Remote Control -...
How do you change the batteries?
Remove the Battery cover on the back of the remote. Remove the dead batteries. Put them in recycling Open the new batteries and install them paying attention to polarity. Replace battery cover
May 06, 2011 | One For All URC-4330 Remote Control
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
Can?t get the back cover off rti T2+ remote control. Need to reattached power plug to circuit board. All screws have been removed seems board snaps in. Any suggestions?
If your talking about the battery cover then you just need to apply pressure to the battery cover near the seam and pull down with your other hand near the bottom of the remote near the battery terminals. If the battery inside has puffed up then the battery cover may be under stress and very hard to remove.
Dec 18, 2009 | Rti Technologies Rti T1 Remote Control
What do you do when it is stuck reading update in progress
After disconnecting the cable from the remote, I would remove the battery cover and the battery. Wait 5 minutes, replace the battery and cover and see what happens. You may need to reprogram the remote after this using the software from the link below.
http://www.logitech.com/index.cfm/440/3864&hub=1&cl=us,en?osid=1
Oct 31, 2009 | Logitech Harmony 880 LCD Remote Control
How to buy a battery cover for harmony remote
Hey!
I had to get a replacement battery cover from the Sales Department through Logitech. Their toll free number is 1-800-231-7717.
I hope this helps!!!
-Kennedy
Oct 27, 2009 | Logitech Harmony 550 Remote Control
Neet battery cover for Philips TSU600 Pronto remote control
Battery Covers sell worldwide at Rogers for around $3-$10. Also, cheaper 50c ones are sold on EBay, Kijiji, and Craigslist.
May 03, 2009 | Philips TSU6000 LCD Touchscreen Remote...
Sony Playstation 3 (PS3) Console Logo
387 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
