Question about LG DLE5977 Electric Dryer
I have a thumping noise as the dryer runs, but it seems to work fine.
  • 1,543 Answers
Look closely at the seam of the dryer drum, at the very front and the very back. I suspect that the seam has developed a crack, and makes a thumping noise each time the crack passes over the drum support rollers. You will have to replace the drum to eliminate the problem
Posted on Jun 28, 2009
SOURCE: Thumping drum noise
ngfam1,
You are reminded, this is a SELF HELP web site. You are supposed to encourage people with you knowledge of how to repair appliances. Not to discourage them and tell them to call a repairman. The whole point of this forum is to AVOID a service call and NOT to promote your repair service. Give you a good rating for what? Stop begging for ratings and start actually helping!
Posted on Sep 06, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
WonderTech
  • 268 Answers
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Posted on Aug 12, 2009
dtci80
  • 125 Answers
SOURCE: My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Posted on Oct 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: There is a squealing noise when the dryer runs.
The drum rides on a pair of plastic glides in the front. They get thin and their bracket begins to rub the drum.
The rollers tend to get a little noisy in time. I use HVAC oil (zoom-oil from ace hardware) to lube them because it is temp resistant, won't disapate, and is non flammable.
Posted on May 01, 2010
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Dryer drum is starting to make a thump, thump sound when rotating. Everything else works fine. Belt is good.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 26, 2011 | Dryers
The dryer works, heats, tumbles, everything is fine. Except that there is a thump as the drum turns that seems to be coming from the top.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jun 17, 2010 | Kenmore 93042 Gas Dryer
Dryer works fine . other than a thumping noise. and a large stress crack in the drum near the front. getting worse.
heatman101
yuuri
May 28, 2010 | LG DLE2514 Electric Dryer
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
LG DLE5977 Electric Dryer Logo
331 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
