Question about Raypak Pool & Spa
Raypak 2100 fault readout said SNS. Replaced the temperature sensor and the fault still says SNS.
  • 1 more comment
  • mentzoo Jun 28, 2009
    Checked both the old and new sensor with an ohm meter. Both appear to be working. Both are at 10.5k ohms at room temp and fluctuate when under warm or cold water.
    Both old and new temperature sensors appear to be working normally (last post). Any other ideas please.
  • mentzoo Jul 03, 2009
    SNS is steady and not blinking (pool mode). Don't see anything in the pdf about balancing the temp. sensor. Cleaned all the sensors contacts and PCB board contacts. Still the same problem "SNS".
    Thank You For Your Help
  • 436 Answers
I think the problem is with the heating element.Please check the coil and see whetwer it is working normally.
Posted on Jul 04, 2009
  • 1,555 Answers
Just changing a good component with another don't help. Might be possible your earlier sensor was fine but disbalanced. You are advised to shut it down for few minutes remove the sensor and realign it as per the pdf manual link provided below.
Your error code on display means "Sensors out of balance. If alternating with temp, may be temporary condition. If display shows only this message (blinking) spa is shut down".
http://www.polytecpools.com/images/pdf/eos.pdf
Save it for your future use also.
Posted on Jun 28, 2009
    Brigadier General:
  • 3,917 Answers
I understand that you have replaced the temperature sensor but since you are still getting the SNS I would request you to check the sensor once again as the meaning of the SNS is:
1) SENSOR IS FAULTY
2) TEMPERATURE IS ABOVE 110°F
3) TEMPERATURE IS BELOW 36°F
There os no further troubleshooting.
Thanks for contacting Fixya.
Code sns appears
temp sensor out of range replace
Aug 11, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypak sns code
bad temp sensor
Apr 06, 2012 | Raypak Pool & Spa
Display is reading sns. what does this mean?
SNS 1) SENSOR IS FAULTY
It is one of the above situations
Apr 27, 2011 | Raypak 2100 Pool Heater Gas 336000 BTU'...
I get sns on my heater
SNS on Raypak heaters means the following:
1. Water temp is below 36 degrees F, or above 110 degrees F.
2. The sensor contains 2 thermistors. If they are more than 2 degrees aparts, an SNS failure will occur. Replace sensor.
3. Loose or corroded connection at P1 on the main CPU board (right behind the LCD screen)
4. If the sensor is not mounted ALL THE WAY into the JACO fitting (on top of the header) it will give a false reading.
It is more likely than not, that you need to replace the temperature sensor. Part number 009577F.
Jan 26, 2011 | Raypak Free Hydraulic Lift Gate Delivery -...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Heater displays SNS - sensor failure. what do i do?
sns occurs when sensor reads temps under 36 degrees or above 110 degrees. check temp of of water to verify.....may need a new water sensor
May 30, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
My raypak heater is not working I have power but the screen is showing an error message SNS. What do I look for what sensor is not working.
Here is the link for the manual for your boiler.
http://www.raypak.com/uploads/6000.59R.pdf
or above 110°F - The water temperature sensor has failed or a wire is broken. (page 35)
Jul 16, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Pool & Spa Logo
311 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
