Question about Paragon 8145-20 Defrost Timer
Paragon 8145-20 defrost timer
Howzit.
I just refurbished a similar size walk in coolroom which had the same defrost timer. The plant is a mix match of different components it worked now its frozen solid after a day of cooling at 3 deg celsius. The evaporator has a element heating set not sure if they are ok, will test them. My actual question is the thermostat, should I put the thermostat with NC, NO swithes close to the outgoing air side of the evaporator? Also once I replace the coil of the 8145-20 timer, setting it up for defrost, do I need the heating elements or can I just prolong the off time without any electrical or hot gas method or will that be counter productive for my coolroom?
I am not professional at commercial refrigeration, and can't answer your question directly.
However, you can see 8145-20 240V defrost timer wiring diagrams and manuals on following link.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145 timer is time initiated, and pressure/temperature terminated, with back-up time termination.
Posted on Feb 06, 2011
Defrost timer 8145-20 goes to defrost end fans go out end heather go in but compresor will not stop
Is this a hot gas bypass defroster with a switching valve? If so, the compressor should be on.
May 07, 2014 | Paragon 8145-20 Defrost Timer
Wiring walk freezer
Copy following link to identify defrost timer.
Add a comment and say which defrost timer you have, which voltage and phase the incoming line
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 11, 2013 | Paragon 8145-20 Defrost Timer
How to wire a paragon defrost timer with liquid line solenoid valve t-stat electric heater for walk in freezer
page 20 in the heatcraft refrigeration manual shows how to interface a paragon defrost timer with the t-stat and evaporator coil.
Oct 21, 2012 | Paragon 8145-20 Defrost Timer
I'm looking for a control wiring diagram for this set up; The condenser is on the roof with a paragon 8145-20 in it. I want to control the defrost cycle of the walk in freezer that is downstairs. The...
Open following link to see wiring diagram and manual for Paragon defrost timers:
8145-20 is 240V time-initiated, pressure or temperature terminated, with back-up time termination.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Paragon 8145-20 Defrost Timer
I am looking for a source to replace timer motors and silver contacts on a bunch of paragon 8025 24 hour timers.
According to e-mail I got from Paragon in Nov 2010, Paragon is no longer making timers and parts.
Except for defrost timers.
I don't know how narrow the Paragon defrost line has become, if they still making their commercial refrigeration timers, or if they're just making smaller refrigerator defrost timers.
Or if Paragon has parts for the 8025
http://www.uni-line.com/common/custserv.aspx
Jan 12, 2011 | Paragon 8025-00 Enclosed Indoor 24 Hour...
I need a set of trippers for a Paragon 4001 switch timer. Need both "On " and "off" trippers. Can you find some?
Paragon 4000 series timers uses X2772 tripper
Google search x2772 tripper
Frontier Lighting shows they are out.
A couple other places show 56-60 dollars for the tripper
In November 2010, I got e-mail from Paragon saying that Paragon stopped making timers and parts for timers, except for defrost timers. 4001 is not defrost timer.
Intermatic has cross-reference link if you want to buy new timer:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Cross reference shows T-101 timer matches your timer.
Aplus supply sells T101 for $60
http://www.aplussupply.com/intermatic/timer.htm
Amazon sells T101 for 43$ with free shipping over 25$
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
T101 wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jan 07, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Set defrost timer on Paragon Electric Defrost-O-Matic
If the air flow and temperature are not being compromised leave it alone. If there is a gradual build up of ice on the evaporator you may have a defrost element or defrost limit switch problem. Set the defrost duration duration to 45 minutes and see if that solves the icing problem. 4 defrost cycles a day should be enough to keep the icing problem at bay. 3 defrost cycles at night about 1 hour apart may also remedy the problem. Experiment until you find the right combination of defrost cycles for your freezer. Watch for any thawing of the product in the freezer and adjust accordingly.
Bills Refrigeration/Montana.
Nov 14, 2008 | Paragon 8145-20 Defrost Timer
Paragon 8145-20 Defrost Timer Logo
649 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
