Question about Frigidaire Freezers
Punctured freon line in freezer
I was chipping the ice off the freezer part of the refrigerator when suddenly freon started spewing out , can I fix this myself and how? Need help fast
  • 1,543 Answers
Please don't rate me down for this answer, but I'll be honest with you. No, you can not fix it yourself. The entire evaporator would have to be replaced by a service tech who has a refrigerant certification and the proper tools to do it. It would be prohibitively expensive. It's time to buy a replacement.
Posted on Jun 28, 2009
Refrigerator side not cooling and freezer not freezing properly. Ice maker not making ice!
call your local repairman . it possibly needs freon added and only certified people can do it .
Mar 17, 2016 | Samsung RS261MDBP Side by Side...
How to add 134a to magic chef deep freezer
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
Nov 08, 2015 | Magic Chef Chest Freezer MCCF5WBX
Freon leak in housing? Can it be fixed
replacing leaking evaporator coil in this video on GE side by side
Jul 22, 2012 | GE FUF17SVRWW Upright Freezer
I have a Kenmore upright freezer and had it checked. The problem was that it want keep food frozen. The repairman put freon in it and said that was the problem. So put cup of water in there overnight and...
If this is a frost free freezer,the evaporator coils could be frozen over with ice,due to a bad defrost system part.
The freezer fan motor may not be working.
There could be a refrigerant restriction in the lines.
The compressor could be bad.
The refrigerant leak could be large and the refrigerant leaks out quickly.
Sep 19, 2010 | Frigidaire Freezers
Only upper section of the freezer works, heavy ice-buildup.
The symptoms you are describing are typically from a refrigerant (freon) leak. Unfortunately it will be as simple as adding new refrigerant as it will just leak out. The leak will need to be repaired. From my experience with this unit my best guess is that the evaporator coils would need replaced. An average repair cost for this type of repair would be around $400.00.
I hope this helps.
May 06, 2010 | Woods Freezers
Ice forming on copper pipe coming from compressor
Hi, It is not uncommon for the suction line on a unit to have ice on it when cooling. This means that where the ice starts forming on the line, there is liquid freon there. But, if it continues to get worse, would indicate a problem as you don't want liquid freon to enter the compressor as it will burn out the valves, or slug it as we say. Icing of this line can be from a few things. Low on freon will cause it to ice up. The freezer fan/evaporator fan motor not working. The freezer iced over real bad. An over charged system will do this, but you haven't had to charge it. Check the fan I mentioned and keep an eye on this line and monitor the units temperature. If you start to loose your cooling then we need to go from there. I can't prevent it from forming ice unless I was on site to install my service gauges to check the internal condition. Please keep me posted though. If the freezer fan is not running, this would be the problem and would need to be replaced. If you had excess to a volt meter and it wasn't running, you could check power to this motor. Let me know if it is not running and check the temperatures closely.
Good Luck,
Shastalaker7
Mar 09, 2010 | Freezers
Gibson Upright Freezer
Is it a self defrosting? Or not? And how did you defrost it?If you scraped and chipped the ice away, you may have poked a hole in the evaporator and the refrigerant (freon) leaked out.
Jan 03, 2010 | Frigidaire Freezers
I have a stand alone freezer model MFU17F3GW8 serial # WB11907298 my problem is that it does not get cold enough. what could be the problem?
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Are the condenser coils on the back warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
evaporator coils are behind the rear cover inside the freezer at the bottom.
observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Compressor or freon problem will require a repairman.
Oct 15, 2009 | Freezers
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Freezers Logo
680 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
