Question about Whirlpool MH1170XS Microwave Oven
Fan does not work...including exhaust fan...but microwave still heats
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hfkk
Posted on Sep 30, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave No longer Heating Food
The most common cause of that is a shorted or blown high voltage rectifier diode.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
More info here: http://www.gallawa.com/microtech/diode.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
SOURCE: Danby Designer microwave (with exhaust
Its a bad magnetron
Posted on Jul 18, 2008
tzweeb
  • 318 Answers
SOURCE: whirlpool model MH7100XYQ microwave, exhaust fan
sometimes the control board will short out and not let the fan or cook top light work.
if you want to try and remove the control board, look on the back of the board for any burnt off tracers. those are the wiring connections on the board that move power from a wire to a relay.
it is usually easy to see the burnt out piece, and if you can solder a new wire across where the burnt out part is, then it should work ok again.
if you cant solder, then a new control board will cost about 125-150 bucks.
Posted on Jan 30, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Advantium 120 - Panel is dead, exhaust fan and lights working.
Chances are you have a bad primary interlock (upper door switch) or a loose or damaged door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jun 08, 2009
localwonder
  • 6784 Answers
SOURCE: microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Posted on Jun 10, 2009
Kenmore model 721 - Cooked a meal for 30 minutes. Afterwards the microwave did not heat. However, the next day it worked. A few days later, was operated for 20 minutes, and again did not heat, and has not...
Yes, there is a thermostat device located on the magnetron. It will open up (turning off the magnetron) when it gets too hot, and it will reset automatically after it cools back down (in 5 to 15 minutes). The question is, Why is is over-heating? Usually it is caused by the exhaust fan being turned the wrong way. (For example, it may be set to exhaust the air out through the top of the microwave, but you don't have a vent there.) That fan can be turned to exhaust air out the top, out the back, or recirculate the air back through the front of microwave. It's easy to turn it around - the hard part is that you have to take the microwave down to be able to pull the fan out and rotate it the right direction.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 17, 2015 | Kenmore Microwave Ovens
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
My Panasonic Over the range microwave Model NN-H264SF front touch pad don't get any beep plus i cannot put any number so microwave don't work. If range get over heat microwave exhaust fan get activated...
it needs to be repaired others have had the same problem.
here's one review...
liked this product very much, until it died after a little under 1.5 years. I brought it to a repair center recommended by Panasonic. They quoted me a parts-and-labor price of around $125 to fix the thing. The repair included a new membrane pad (the buttons on the front), new fuse, and new fuse holder.
The repair center told me they've been instructed by Panasonic to replace all old fuse holders with newer, better ones. Apparently, the original fuse holder was somewhat defective, causing the fuse to burn out. I don't know if this bears any relation as to why a relatively new membrane pad might have gone bad, but it's certainly annoying for a device costing several hundred dollars.
Feb 07, 2018 | Panasonic Microwave Ovens
My 900 em do oven keeps over heating and switching off
follow thes steps and fix it.God bless you
Exhaust Fan Motor
If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it doesn't, replace it.
Thermostat
If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board
If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.1_24_2013_5_50_54_pm.gif1_24_2013_5_53_00_pm.jpg
Jan 24, 2013 | Microwave Ovens
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Microwave shut-off within 2-3 minutes
Why don't you return it? I think this is a common problem. We returned ours to Home Depot with no questions asked.
Nov 12, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
401 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
