Question about Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
We just purchased a whirlpool dishwasher & while taking it out of the box I noticed a gray piece in the lower back with a red electrical part in the middle with a wire connected hanging down. I looked up the part number to find out it was an actuator. The little black plunger was broke. What does this actuator do & what should I do about it?
  • duncan2458 Jun 28, 2009
    thanks! just for future reference what does that actuator do? I am an information nut & like to know about things that I never knew. Any info would be appreciated.
    Jim
  • 999 Answers
You just got it. call for service or take it back for a replacement. If that piece was damaged, what else was jarred and soon to fail. I would return it for a replacement.
Eric
Posted on Jun 28, 2009
  • Eric Duda
    Eric Duda Jun 28, 2009
    I cannot picture what you are describing. If you can email me a picture erpaalai@verizon.net I might have a better shot at identifying it for you or give me the part number you are referencing.
    Eric
The detergent latch on my Whirlpool Quiet Parter III dishwasher keeps falling out. Not the lid...just the little gray latch with the red rubber ring.
I would replace the dispenser. It is made out of plastic and only holds so long. If you provide with me with the model #, I will supply you with a part # to purchase.
Mar 12, 2014 | Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Quiet Partner II model DU1100XTPQ7. The top rack is not clean after the dishwasher runs. We cleaned both sprayers with pipe cleaner & ran water through the lower sprayer with a...
Hello Tx_smiths! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Tx_smiths), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 19, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
The rotating piece on the bottom of my Amana QT is not rotating
check that the upper and lower spray arm nozzles are not clogged with particles if they are remove them a nd clean them out also see if there is a screen in the bottom of dishwasher under lower rack clean it out if you can also purchase a bottle of dishwasher cleaner from your local supermarket use it in a empty dishwasher first run tap closest to machine to make sure water is hot red directions on bottle it works very well and dishes will come out much cleaner also use a good gel like electra sol dihwasher gel
Jul 21, 2009 | Amana 24 in. ADW862EAS Dishwasher
How do you fit the upper spray arm to the back of the dishwasher
The upper spray arm does not fit on the back of the dishwasher. There is a separate "Extra Tall Item Sprinkler" piece (about a 3-4" round gray piece that looks like a shower head) that mounts in the back of the dw.
Note that this option is only to be used with the top rack removed (i.e., for washing tall items in the lower rack). Refer to page 37 of the Use & Care Manual that came with your dishwasher.
Jun 23, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Water leak at heater element connection seal, rusted connection
Mlecha, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Mlecha), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool DU1055XTSQ Built-in Dishwasher
No power want come on
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
Also check wire nut power connections at the machine. Remove toe panel. There is an electrical box on the right side.
Jun 19, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Rinse and dry
You probably don't have enough pressure from the pump. That's most likely caused by a clogged filter. So start by checking the filters- the easy one to get to is located behind the chopper in the base of the dishwasher. Grab the whiteish tube going from the bottom of the dishwasher towards the back of the dishwasher and get it to spin about 1/8th turn clockwise and then pull up. If that part works out for you, you'll see four torx screws. Don't loose any of these, they cost $6 each. Take out all four and pull the round white thing up and set it aside. You'll see gray plastic now. Towards the front, down inside, you'll find two more torx screws that are smaller than the first four. Take those out and get the two gray pieces they hold down out of your way. The flat one will come out easily, the other one will take some persistence. Once you get that out, you can see the smaller filter behind the chopper. It sits inside a thin groove, pay attention to this groove, as you'll want to put it back in the wrong place if you don't look it over before you take it out. Remove the filter and chopper assembly and clean it off if it's a mess. Then put the thing back together the same way you took it apart.
If this fixes your dishwasher, then you know pressure was your problem. If the problem reappears and you follow these steps again only to find the filter full of food again, then your chopper isn't chopping anymore. This is probably because the end of your impeller is broken off and isn't engaging the chopper anymore. If that's the case, replace the impeller (about $20 new).
To replace the impeller:
SHUT OFF THE ELECTRICITY to the dishwasher and unhook the wires in the electrical connection box. Notice that (hopefully) the white wire connects to a white wire and the black wire connects to the black wire and the green or bare wire wraps around a screw. You'll need to reconnect this back properly when you're finished with everything else.
Disconnect the drain line, either at your garbage disposal or at the dishwasher if you can get to that connection. Watch out for water, it'll go everywhere when you pull this loose.
Turn off the source of water, if you don't have a valve under your sink for this (you'll wish you did) then you'll need to shut off the water to your house. Disconnect the water supply line from the dishwasher, this connection is underneath the dishwasher opposite the electrical connection box.
Pull the dishwasher out and flip it over 45 or 90 degrees, your choice.
Unscrew the capacitor from the motor assembly (it's the round looking thing with two wires mounted to the motor), but leave the wires connected to it. Put the nut back on the bolt so you don't loose it. This makes getting the thing out easier.
Find the drain pump, it has a plastic tube connected to it. There is one torx screw holding that in. Take the screw off, pull the tube and the white thing with wires out, leave its wires attached. Your model may not have wires here.
Pull the wire connector off the motor. Remember where it went. Pull the two wires off the thermistor, they should be Yellow (with a black stripe) and white. Make a note that these two wires go on the thermistor so you get them back in the right place. Pull the Blue and gray wires off the drain pump. Make a note that these go on the drain pump so you get them back in the right place.
Next, there are three tabs that you need to find and pull out. They are little L-shaped wedges that hold the round gray assembly to the dishwasher. They are located about 1/3rd of the way around the circle, so once you find one, the other two are pretty easy to locate. Do not loose these parts.
Once you get those pulled out, the entire gray assembly can come out.
Look behind the motor for a bolt. Get your socket set out and find a 3/8ths socket. Put that on an extension, and the extension on your ratchet. Slide the socket between the white plastic protector and the grey plastic (it's a tight fit) and take out the bolt. Do not loose the bolt. Leave it in the plastic so you'll remember to put the plastic back. Grab the motor and turn it about 1/8 to 1/4 turn (it will only turn one direction) and then pull it out of its housing.
From here you can access the second filter, the one that isn't so easy to get to. It's probably fine. And now you can see the impeller, it's white and black and attached to the end of the motor shaft.
To remove the impeller, stick a screwdriver into the back of the motor, being careful not to damage the windings. Hold the screwdriver with one hand, grab the impeller with the other hand and unscrew it from the motor shaft.
Install new impeller on the end of the motor shaft, make sure it's tight.
Reverse instructions to put it all back together. Make sure you get the thermistor and drain pump wires connected correctly. White/Yellow to thermistor (little round dodad) and blue/gray to the pump (big thing on the gray part that drains water from the tub.)
Don't forget to re-attach the drain and supply lines, turn on water and check for leaks. Fix leaks. You may need Teflon tape, depending on the type of supply connection you had to undo. If you use plex tubing and connectors, you don't need Teflon.
Do NOT turn back on the electricity until the dishwasher is completely wired back up, closed, secure, and don't forget the ground (bare or green) wire around that screw.
I'm not responsible if you follow these instructions and end up shocking or killing yourself or your dishwasher. This is what worked for me.
Dec 15, 2007 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Soap scum on dishes and glasses
These instructions will work for almost any GUxxx series whirlpool dishwasher:
Sep 26, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher Logo
77 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
