Question about Samsung HT-X200 Theater System
HELP! Hi Our system no longer plays our disks just makes a whirring noise but doesn't play anything at all - no picture no sound?
Try holdin machine at a 45 degree angle....the laser is off line slightly and can't read data
Posted on Aug 06, 2009
Heater fan is making noise. Sounds like motor bearings
This may or may not help you.If the sound you hear is a constant whirring/grinding sound it may be the fan motor.If the fan takes a few seconds longer to speed up when you increase the speed it could still be the fan.If the sounds you hear are clicking sounds and they get quicker or slower as you play with the fan,it may well be leaves or junk in the fan housing.Its a common thing.Hope this helps you either way
Jan 08, 2010 | 2003 Volkswagen Passat
A Sony RDR-GX210 DVD player I can play a CD - no problem but when I try a DVD, the TV screen says - ''loading please wait'' and then it drops back to the TV picture witha message - ''Can't play this disc''...
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Sep 08, 2009 | Sony RDR-GX300 DVD Recorder
My wii is making a clicking sound when a game is in play why?
Thats fine. Its probably a little older and if you put any more Wii channels other than the original ones, It takes memory and it needs more computing time. The clicking noise is similar to the whirring noise in a computer. It is reading the disk
Feb 21, 2009 | Nintendo Wii Console
Unknown disc error and whirring sound!
Do you leave the unit on all day and night on standby?
If this unit gets to hot you can experience this problem I suggest that you turn the power OFF totally until the unit cools down and try again. Normally 15 mins is enough.
Feb 01, 2009 | Philips DVDR3380/05 DVD Recorder
My Xbox 360 Premium makes noise and doesn't load. How do I fix it
It sounds like you need the dvd drive replaced. It could also be your motor or laser which needs replacement. We can offer you this service if interested email us for estimate.
xbox360fixer@verizon.net
Jan 12, 2009 | Microsoft Xbox 360 Console
Cant take picture
The lens assembly and or microprocessor has failed.
Contact Olympus
Good luck, Paul
Jun 06, 2008 | Olympus FE-230 Digital Camera
Won't play purchased dvd's
i,d suggest laser head problem.
Dirty-weak laser unit. try a head cleaning disk.
Mike @ compurepair.
Feb 25, 2008 | Amphion Mediaworks T342 System
Dvd won't load
open it and check for a broken part in one of the gears that operate the drive. if the unit is under warranty, take it back rather than try to fix it.
either something is in the mechanical portion of the unit, or it is badly worn.
i would suspect a broken part from the noise issue/ clicking sounds.
the read head runs on a track and could be jammed up, unable to run to access the directory of the disc. inspect what you can get to, and hopefully that will be a simple fix.
good luck
mark
Jan 05, 2008 | Symphonic SD200E
My dvd won't play any movies
the ticking sound is most likely the laser hitting the disk trying to focus, my guess is the motor isnt spinning the disc or the laser is bad or weak.
Dec 04, 2007 | Symphonic WF104
Samsung HT-X200 Theater System Logo
394 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
