Question about Saniflo &Sanigrind Water Pump
I have a sanigrind from saniflo and there is dirty water coming from the little hole in the bottom of the electrical subset box. Could someone help me get to the bottom of this.
    Scholar:
  • Saniflo Expert
  • 115 Answers
The Sanigrinds are a little harder to work on. Most likely the electrical subset is broken this is why water is leaking out of there. You will have to replace the electrical subset, be careful though. If not aligned properly, it will brake again upon installation.
Posted on Jul 30, 2010
I have a Panasonic a/c CW 500 RU. Hw do I find the drain pipe?
you can try to pull the unit out and take it outside and wash it out with a water hose just don't get the electric parts wet sounds like it may be dirty there should be drain holes on the bottom of the case.
Sep 18, 2014 | Panasonic Heating & Cooling
Problems with the elbow coming off of macerator.
Ontact Saniflo they will send engineer out to rectify.
Nov 30, 2017 | Saniflo SaniPlus-Round SaniPlus Macerator...
Pump continues to work long after toilet has been flushed as if the saniflo pump is unable to pump all the water out at once like it used to. There is no clog in the vent line, and only a partial block if...
I know nothing about the Saniflo system but I suggest you check in the supplied literature if any routine maintenance is recommended and if so I think it would be wise to do that before looking for further explanations (problems).
Nov 07, 2017 | Saniflo SaniGrind Grinder Pump (Toilet...
I have just had a saniflo installed. When I put the power on it knocks the trip switch on the box straight off.
That means that somehow water got inside the pressure chamber which is where all the electrical components are, if it senses water it will trip the GFI and the unit will shut off completely. You may have to replace the whole pressure chamber since water may have corroded the electrical components.
Mar 02, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
The macerator wont turn off after toilet flushed - have taken it apart & cant see any obvious problem - what next ?
try cleaning with an acid descaler. if that doesnt work then its time to replace the pressure switch (micro-switch). These often give up well before the unit has reached its last legs.
Apr 02, 2010 | Saniflo &Sanigrind Water Pump
Sanigrind pump don"t always start on all fushes
certainly indicates that the unit is not holding water (hence not starting on every flush). as you are seeing water in the shower - this is obviously where it is going. It may be that the internal flap (non return valve) is stuck open or damaged. If damaged you can put a new non return valve in your 40mm pipe run where the shower pipe enters the saniflo - about a tenner from most suppliers.
Feb 13, 2010 | Saniflo & Saniplus& Macerator Pump
Hi there, we have a Saniflo system for a basement bathroom installed. The system stopped working so we checked the fuse box and it had tripped. We switched it back on and it worked fine for an hour. We had...
The saniflo system uses 2 stages stage one works sorta like a garbage disposal it breakes up waste, stage two is a high flo pump. one fo these has gone bad meaning the motor has burned up and shorted the sparking in the breaker pannel you refered to. As far as I know theese systems are self contained so you will have to have the unit repaced here is a link to the website so you can find a dealer or installer near you
http://www.saniflo.com/Default.aspx
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Kitchen Appliances - Others
Saniflo &Sanigrind Water Pump  Logo
103 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
