Question about Bosch Washing Machines
Washing machine does not spin, Bosch WF024564GB/01 jumps from 11 mins to 1 min . no blockages drains and fills, pumps run, belt fine, is this a control module fault ?
  • 82 Answers
Check the brushes on the moter
Posted on Jun 28, 2009
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Machine worked fine last night. This morning spin not working. Have tested it empty, put it in spin program, a funny clicking noise and then nothing, then after a while indicator shows 01 - ie. finished!...
n most washers the F01 error indicates an control board problem. It is like an internal program error.
A power glitch can cause the problem.
One of the things to try is to enter and run a diagnostic cycle, or unplug the machine for 30 mins.
Jan 24, 2011 | Bosch Classixx WFO 2866 Front Load Washer
Machine selects a program fills up with water then does nothing, but still makes usual clicking noises. If drain is selected machine indicates 12 mins as normal starts to drain then shows 1 min and does...
This sounds like a bad main control board. Try unplugging it for 10 minutes then replug an try again. If you get the same results replace the main controller.
Jun 16, 2010 | Bosch Exxcel WFX 3267 Front Load Washer
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
bosch exxel 1200 washng machine
has error message 04 and wont drain or spin
what does this mean?
can you help?
have lost instruction book
Mar 27, 2008 | Washing Machines
Washing Machines Logo
192 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
