Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftmen mower doesn't cut well on right side
I have a Sears mower with a 42" deck. The right side doesn't cut well as the left side. I have new mulching blades and the kit on the mower. I am not cutting much off the grass. The grass is burmuda and the grass looks like it is just bent over. I have to recut to make it look better.
Any suggestions?
  • awklee Jul 05, 2009
    I checked the blade. It is installed correctly. The mandrel bearings were bad and dragging so the blade would not spin fast enough. I also noticed this was causing wear on the belt so I changed that also. I changed the mandrel and belt and the problem went away. Thanks for the suggestion.
  • 376 Answers
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Posted on Jun 28, 2009
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
42 inch mower cuts uneven, what is the problem?
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What type mulch kit do I get. One says stamped deck zoom 34
Mulch kits are a waste of money. If you have high lift mulching blades you keep the grass in the deck long enough to do the desired cutting. Open the deflector and block it open with a bungee strap and let the blades spread the grass,so you get no streaking or wind rowing.
CAUTION
Always discharge away from PEOPLE and Buildings and automobiles. I cut an acre here that looks like any golf course with NO MULCHING KIT. MULCHING BLADES ONLY.
Oct 19, 2009 | Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
763 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
