Home | Bialetti | Moka Express 6-Cup Coffee Maker | Barely any coffee ris...
Bialetti Moka Express 6-Cup Coffee Maker
Problem for Bialetti Moka Express 6-Cup Coffee Maker
Barely any coffee rises to upper chamber after cooking
By nicky4 on Jun 28, 2009
When I first bought it, it worked just fine even though I noticed that not all the coffee was brewed to the upper chamber.. There was always some coffee water still left in the bottom chamber when I would clean it. Then one day it started working great, where it would use all the water I put in it and make a full to the tippy-top cup of delicious coffee. I tend to grind the coffee not as fine as espresso but finer than a drip coffee maker. Now the bialetti only brings up two tablespoons of burnt coffee after it has been trying to brew on even temperature for 20 minutes. And I even put in a new gasket used the same ground coffee and it seemed to make it even worse (only 1 tablespoon of burnt coffee). Hope you can suggest something more to the juggular of the problem. Thank you. M Vekkos
Best Solution
posted on Sep 12, 2009
Very Helpful)
7054mwc
Rank: Guide
Rating: 92%, 3 votes
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 16, 2009
Not Rated)
colebeck
Rank: Apprentice
Rating: 75%, 2 votes
Try replacing the funnel cup [the one you put the coffee in] as well as the gasket [Amazon UK sell them for less that £2!].
I've just suffered the same but changing the funnel cup worked first time!
Was this helpful?
Yes
No
Popular Solutions for Bialetti Moka Express 6-Cup
Questions and Unsolved Problems for Bialetti Moka Express 6-Cup
Do you recommend Bialetti Moka Express 6-Cup Coffee Maker?
Answer
Answer
How long does it take for the water to reach the top of the tank? Also, the sales clerk sold me... (More)
Answer
My bialetti coffee maker ends up boiling the coffee if left on the stove. Is it meant to do this?... (More)
Answer
When I first got my Bialetti Mukka, it would leak from the sides.  Online, I found the fix of... (More)
Answer
The pressure valve on my Bialetti 6-cup Moka espresso coffee maker blew out after 1 month. I have... (More)
Answer
When I add water to the bottom (top of the filter) I can not get water to drop down into the chamber... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bialetti Moka Express 6-Cup...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
