Question about LG LRE30755ST Kitchen Range
The two large burners will not turn on, it started with just the inner burner on the dual size (the switch showed it on but it did not heat) now neither front burner switch will turn on
You are going to have to buy a new burner part. if you are able to open the stove top and look closely at the element inside you should notice that somewhere along the lines of teeth, it has broken.
Posted on Jul 19, 2009
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
My large burner does not heat up fully...the outside ring does not heat, only the inside, is this a fuse issue and where do I find the fuses?
The problem with that is going to either be the outer ring of the burner burnt out OR the control sitch for that burner. THier is no fuse for the burners, the switch for that dual burner is part number 74003122,the part the dual burner is 12002144
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Aug 15, 2011 | Maytag MER5870 Electric Kitchen Range
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
I have a Whirlpool Gold Accubake Stove with ceramic top ( approx 9 yrs old) ..the dual burner (one size for smaller pots vice versa) will only heat both burners even when you only turn the smallest part of...
This is becoming a common problem. If your dual burners are controlled by the burner switch only, then you need to replace your dual burner infinite switch. Some models have a seperate rocker switch that switches from small burner to both burners. If you have this style then this is usually your problem. Can also be from shorted wiring but this is very unlikely. Good Luck, Appliance Specialists
Dec 11, 2009 | Microwave Ovens
My dual size burner only goes large no matter the
You will have to have the potentiometer switch replaced that controls the burner.
Aug 30, 2009 | Jenn-Air Cooktops
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
LG LRE30755ST Kitchen Range Logo
541 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
