Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a h400 gas heater. keeps shutting off reading 1F code
If the heater is cycling on and off continuously the problem may be a dirty filter. Try backwashing and rinsing the filter before anything else.
Posted on Jul 04, 2009
I have a Hayward H400 that shuts off at 88 degrees. What could this be?
Is this heater standalone, or is it hooked up to an external controller? If it is standalone, it sounds like you need a water temp sensor for the heater. If its hooked up to an external controller, you likely need a 10k temp sensor. What error code does the heater display when it shuts down? And what temperature are you able to read on the heater and/or external controller?
Aug 25, 2014 | Hayward H Series Pool & Spa Heater 400k...
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
Aug 09, 2014 | Hayward Pool & Spa
BO code heayer keeps cycling on and off
check to see if proper gas pressure call gas company give them added total thems all your appliances use they probably will give you a bigger meter then everything will run efficiently
May 24, 2014 | Hayward H-series Electronic Gas Pool...
1F Error Code on Hayword Heater
IF stands of igniton failure. Many things can cause this. Most notable, is a clogged or dirty burner orifice. The two middle ones are the most important. But i would clean them all out. They remove with a 5/16" wrench. Improper gas pressure could also cause this. However, you need a special tool, a manometer, to read this.
May 05, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
543 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
