Question about Whirlpool Dishwashers
My dishwasher will not fill with water therefore i can't use it. the moter is running but no water intake
  • 999 Answers
Check the power coming to the water valve during the fill cycle. If power is there the valve is shot or the screen is plugged. remove the valve and check the screen or replace if clear.
Eric
Posted on Jun 28, 2009
IE error on LDF6810ST, it's not the valve or the controller
Try to check water flow sensor that attached to the water intake plastic thin container. It's located from the inner side therefore you won't see it from the first glance. You have to take it apart then find it from the inner bottom side.
Jun 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher does not fill with water. Moter or pump is running but machine will not fill with water.
The first thing to check is the float. Remove the lower rack, in the front right corner there is a plastic float that looks like a hat. Check to make sure something like a spoon is not stuck under it. The float should move up and down about 1/2" freely. If it is stuck up the dishwasher will not fill.
The second cause could be the house supply got shut off under the sink, this would only happen if you had someone working under there.
The last thing would be the water valve on the machine. If you take the two screws out of the lower kick panel it is located near the front left corner. It has 2 wires and 2 hoses going to it. If you have a meter you can check the coil for resistance or power to the valve when trying to fill.
Let me know if you have more questions.
Apr 30, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't start until running until at
The 2 minutes is most likely the "Fill" time in the cycle therefore since the water supply is active the fill solenoid is spent or not getting a signal.
Dec 12, 2009 | Kenmore Dishwashers
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Sep 17, 2009 | Frigidaire PLD4375RFC Dishwasher
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
Apr 15, 2009 | Miele 24 in. G892SCU Plus Built-in...
Water coming into dishwasher when not running
Removed intake water valve assembly and found a piece of plastic wedged in intake port preventing valve from closing. Piece of plastic was old filler tube from old hot water tank which disintegrated and got into hot water pipes in home. Similar pieces of plastic have affected water mixer valves at various sinks in home and have also plugged aeration screens.
Jan 13, 2009 | Dishwashers
Miele dishwasher g664 12 years old maybe?
Hi Lawrenceo,
I'm Harvey the Master Plumber.
You stated your problem as: the dishwasher won't drain.....can here a valve opening and gurgling but then no water exiting. Have cleaned everything and pushed water via tap back through water-exit hose.I to have a Miele G664 dishwasher and when turned on no water no fill. Just sits there with a moter running. Un able to get anyone to come and have a look at it as I live in Mount Victoria NSW.
It sounds like the pump has failed. The motor and the pump are two different parts. This is a common problem with older units. Frankly, after 12 years of use, at least you got your money's worth. At this age, to repair it is to throw good money after bad. It's time o replace it. You'll find there are much nicer models available now.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Dishwasher not running
just got this, and have same prob, i have run through all checks
Aug 26, 2006 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
60 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
