Question about Hitachi 43UWX10B 43" Rear Projection Television
The tv is showing everything kind of double and everything is double lined in red and green
  • Hitachi Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
78The tv is showing everything kind of double and - e87380c.jpgclass=
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. IfThe tv is showing everything kind of double and - 69189a5.pngo fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
My big screen magnavox tv shows double lines red and blue
Model number listed here unlikely to have this issue which sounds like a convergence problem.
Oct 21, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
