Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Clutch ont engaging
I have a yardman 13.5HP 38in. When i push the brake pedal (clutch pedal) all the way down and place in park and the release the pedal my tractor takes off at full speed. It does not matter what gear i have it in it still moves at full speed ( reverse or froward) It is like all my gears are stripped or something. Can anyone help
  • Dwain Pippen May 11, 2010
    Sounds like the shift lever a become detached, What is the model number under the seat, not what is written on the side of the hood?
    Scholar:
  • 173 Answers
I would bet that the Torque converter, (which is the big pulley, with a wheel in between).
Has become jammed, and needs freeing off.
Due to the fact, that they can't be lubricated.
You will probably need to to remove it, completely, to do this.
However, it's not too painful a process.
Hope that's solved it:)
Posted on Jul 25, 2009
Need a clutch pedal diagram for a 1999 s10 2.2 4cyl manual trans
Sorry no diagram. But here is how it works. In the start position(Power) the wire goes to the start fuse, from the fuse it goes to the clutch pedal switch. Push the pedal and it goes to the starter relay. On the other end is ground. If it is good it pulls the relay closed. On the closed end is battery power to the starter.
Mar 09, 2016 | 1999 Chevrolet Silverado 1500
How to set and release the brake
You would depress the clutch/brake pedal all the way down and then pull or activate the brake engage lever or linkage. To release it normally all you have to do is fully depress the clutch/brake pedal and the linkage or lever will automatically disengage.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_73617967471ec7c4
Jan 20, 2016 | Garden
What do i do if I released the park brake but its still stuck
If it is the park brake not releasing it might be a brake shoe that is not releasing. Put the vehicle in reverse and pay the clutch engagement (release - push down) to induce a oscillated motion to the vehicle. The brake should release. Servicing of the brakes should be done as soon as possible as binding should not occur when the park brake is used.
Apr 09, 2015 | Cars & Trucks
Clutch not engaging
Well, it would shift easily with engine off, because the transmission input shaft is not turning. Engine running and clutch engaging good, the input shaft would again be stationary and allow smooth shifting.
What you have to determine is if the clutch disc or pressure plate is bad (a new clutch is needed), or if the pedal hydraulic system has a malfunction. When you push the pedal down, a rod from the top of pedal pushes into the clutch master cylinder bolted to the firewall under the hood. This cylinder has a reservoir filled with brake fluid. When the rod forces fluid from the clutch master down a steel line and into the clutch slave cylinder down on the transmission bell housing, the hydraulic pressure forces a plunger from the slave cylinder to extend and push the clutch fork lever a small amount, enough to force the clutch release bearing (aka throw-out bearing) against the pressure plate. This relieves pressure on the clutch disc and input shaft becomes stationary for easy shifting.
Jul 26, 2013 | 2000 Chevrolet Blazer
My clutch won't engage 1997 Honda civic
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
Apr 06, 2013 | 1997 Honda Civic
Int 806 will not move clutch is new
Fit 4th gear Release hand brakes on strait floor with open hood and push the car back and Forward to see if the engine engage your gear box if is not your clutch is back to front.if engage press the clutch pedal to make release of the gear,notes mechanical clutch cable or hydraulic system. check Release bearing arm position.
Sep 29, 2012 | Peugeot 806 Cars & Trucks
1998 Ford Taurus SE, Problem Transmissions wont Shift, Took it to the Shop and they Said it Had to be a Electracal Problem?? But they did not Know what, Some times Works Fine Other Times Check Engine Comes...
TRY THIS I BET IT'S YOUR PROBLEM
Neutral Safety Switch
  • Put the selector in the park position.
  • Loosen the screws on the neutral safety switch.
  • Remove the switch.
  • Reverse the procedures to complete the installation.
Clutch Start Switch
CAUTION
Before replacing the clutch switch or any component connected to the vehicle's control computer, disconnect the negative cable from the battery.
  • After replacing the switch, slowly work the clutch pedal and note any unusual noises or interferences with pedal movement.
  • If the switch is adjustable, make sure the clutch pedal height and push rod (free) play are correct.
  • Then check the release point of the clutch.
  • Begin by engaging the parking brake and installing wheel chocks.
  • Start the engine and allow it to idle.
  • Without depressing the clutch pedal, slowly shift the shift lever into reverse until the gears contact.
  • Gradually depress the clutch pedal and measure the stroke distance from the point the gear noise stops (this is the release point) up to the full stroke end position.
  • If the distance is not within specifications, check the pedal height, push rod play, and pedal free play.
  • If the distance is correct, check the clearance between the switch and the pedal assembly when the clutch is fully depressed.
f_mt_tps9.26.jpg Clutch switch to pedal assembly clearance. Courtesy of Toyota Motor Company.
  • Loosen the switch and adjust its position to provide for the specified clearance.
May 22, 2010 | 1998 Ford Taurus
Parking Brake problem
2000 S-10: brake functions properly while pedal is held down, but when I remove my foot, the brake is released.
The following is not a repair so much as a solution to the basic problem and I guess it won't pass scrutiny of any state inspection. Nevertheless, this idea may skip around the automatic pedal stop malfunction and buy you some time while a proper part replacement is arranged.
The release cable ends at the ratchet assembly by the pedal and the lever which receives it can be pushed forward before depressing the pedal thereby engaging the stop which will hold the pedal down and keep the brake engaged. There is no click, or catch evident when the release lever is moved forward and it only moves a little bit.
Not the easiest reach from the driver’s seat. Also, the release cable is likely to jump out of its place if you just reach blindly and push.
From what I've read on this site, there are some design issues with the ratchet mechanism that commonly lead to failure of the pedal stop function.
Hopefully this will help those who still want to park on a hill.
Jan 21, 2009 | 2000 Chevrolet S-10
Tdi clutch pedal pushed all the way down but hard to shift gears
Check your clutch fluid level, sometimes a seperate reservoir (drivers side on firewall), some clutch systems take fluid from the brake system (check brake fluid). If thats ok then the clutch slave may be failing.
If the clutch fluid is low refill it and check for leaks (or just wait till the symptom comes back). If it's happens often then theres a leak in the line or the slave somewhere.
Jul 08, 2008 | 2001 Volkswagen Jetta TDI
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
349 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
