Question about Belling XOU252 Electric Single Oven
Why is the fan on my belling xou489 grill stopped working
2 Suggested Answers
SOURCE:
barkencoa
  • 3463 Answers
SOURCE: Hi the fan on my belling ce1100df grill has
More than likely to be a faulty fan, you need to check to see if the fan is a getting a supply to it, if it is, and it is not working, then you need to replace the fan.
Posted on Feb 24, 2010
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Hi the fan on my belling ce1100df grill has stopped working so the element keeps cutting out is this the thermostat or the fan because the red temp light still comes on any info would be appreciated
Feb 24, 2010 | Belling Ovens
Have no signage on knob for top oven/grill..how do I know f it's grill or oven on when I turn it on?
If you turn the grill on, then only the top element will get hot in the oven.
if you select oven and it is fan assisted, then you will hear the fan working, and feel it blowing hot air.
Hope this helps.
Dec 24, 2009 | Belling XOU252 Electric Single Oven
My Belling XOU179 has stopped working. The grill still works but the oven does not heat up - any ideas? Also, can anyone tell me how old this model is? Frances
If it is a fan assisted oven and the fan is working o/k, then you need to replace the oven element. I think that your model is quite an old one going by the model number.
Please rate my solution.
Thanks.
Nov 09, 2009 | Ovens
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Belling db3 oven
yes its most likely the element they are common in burning out ....because the fans still running,
Dec 17, 2007 | Ovens
Belling XOU252 Electric Single Oven Logo
Top Belling Ovens Experts
Marvin
Marvin
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
