Question about Cuisinart Grind & Brew DGB-500R, 12-Cup 12-Cup Coffee Maker
Coffee maker with grinder--sometimes, when percolating, it overflows
    Scholar:
  • 40 Answers
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
Hi,i have a Dualit coffee percolator which has suddenly stopped working,have you any advice as to how I coud fix this - could it be the pump?
Is it the electrical part? Are the lights on? If the lights are on then it is probably the flow of water. Hard water will stop it from working. Sometimes there is a blockage. You can try to put CLR or vinegar through the machine. You may even want to find someone with an air compressor. If you blow air from the "out spot" it can clear a blockage. If is difficult to tell without having it on front of me.
Sometimes the heating element can be burnt out or a wire is burnt off. Examine the wiring on the inside for any burnt wires.
Jan 27, 2015 | General Coffee Percolator Gcp60 60 Cup...
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Overflowing coffee maker
could be using incorrect filters for a different coffee maker, sorry if this sounds obvious but this is the first thing i would think it was unless the water flow is adjustable and coming through quicker than the filter can drain it through
Apr 29, 2013 | Cuisinart Grind and Brew 12-Cup Coffee...
Maui outlets for Farberware percolator do not carry filters? Why?
I think it is because water goes through the coffee while it goes around and through the pipe inside the percolator Let the coffee stand for a few minutes when it is through, then .the coffee will be fine.
enjoy your coffee
kolbrun
Jul 03, 2012 | Farberware FCP280 Stainless Steel...
Hi. On the Breville CG10 coffee grinder, is the higher the number the finer the grind or the other way? Thanks.
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Aug 21, 2010 | Breville Coffee Makers & Espresso Machines
Delta coffee maker: grinder not working
check the service section within your manual.
If you don´t have one, check here:
http://manualfox.com/
They can get you any Delta Coffee Maker manual. Just send them a request.
Jul 08, 2009 | Coffee Makers & Espresso Machines
Regal Ware coffee maker 58001R not brewing
I'm afraid the heating element is burned out.
Feb 24, 2009 | Regal Ware 58001R
Cuisinart Grind & Brew  DGB-500R, 12-Cup 12-Cup Coffee Maker Logo
206 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
