Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
Cannot install windows xp
I have an Asus p4b motherboard with 1.5 gb of ram. Every time I try to install windows xp pro it runs through the setup, but when it tries to to initialize windows I get an error message "session3 initialization error".
It says it does not want to damage my hardware. Is this a bios problem?
I tried to find a bios update but I can't seem to find the correct version of my chipset and bios info. It is supposed to be an Intel 82845 chipset.
Before this I ran fdisk incorrectly and i need to properly partition and format my c: drive and d: drive (i have two hdd). I have an iso of xp pro with sp2 that is bootable but I can't get it to initialize. Help please!!!!
  • 1 more comment
  • averagejoe10 Nov 07, 2007
    I have no usb devices hooked up and the memory is brand new. The video card is brand new. It is an ati radeon 9250 with 256 mb ddr ram. Do I need to press F6 and install the drivers for the video card before it tries to initialize windows.
  • averagejoe10 Nov 08, 2007
    I went into the bios setup and disabled the ultra dma option for my e: drive because it did not support it. After that it booted up.
  • Anonymous May 19, 2008
    when i install windows xp i get the message saying session3 initiasation failed and show alot of zeros.
    Stephen
Hi There,
I had a simlar problen caused by a bad stick of ram memory.
Was able to remove the bad stick of memory(from DDR1) and insert the good stick(from "DDR2") into slot "DDR1".
If you can boot into bios, Enable the "POST" test Display and Disable the "quick boot". Now when you reboot you can see the results of the "POST" test. If there is bad memory you will see the "memory test failed".
The above may take 5 seconds longer to boot your system but you can see what is happening.
Good Luck,
Al Whitmire
Posted on Dec 03, 2007
    Champion:
  • 208 Answers
Sounds like a bad usb device or memory. try eliminating unnecessary things.
Posted on Nov 07, 2007
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Is 2 gb ddr ram is compatible with asus 845 MB......
hello,
if you go to http://www.crucial.com
do a search through the make and model of your computer
it will tell you what type of memory will work best.
Dec 20, 2010 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Asus Motherboad P4B screen
I think the problem is on your motherboard, because in this time windows is not loaded yet. So, check out your motherboad, or take it to service center (if you have no experience in hardware fixing)
May 15, 2009 | ASUS (P4BGV-MX) Motherboard
I have the 845gl mother board. this board ram capacity is 128mb n i want to upgrade ram with 1 gb ddr2
Greetings,
Your motherboard has 2 slots, each can hold 1GB memory of DDR1 which is a PC2100/PC1600.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Upgrading ram
Well with this type of motherboard yes you can put 1gb into it however you can put up to 2gb on it and be just fine. Hope this helps you out.
Apr 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Hard time getting new build to boot...
sounds to me like you either have a conflict of hardware or your os windows xp wasn't meant for your hardware some manufacturers design there products now to be vista only so read you manuals and make sure of that then try reloading xp but with bare essntials to run a pc that is
Mar 15, 2009 | Computers & Internet
Could not detect HDD on my Asus P4B-M Motherboard
hi,
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Video Controller
install video card driver
Oct 12, 2008 | ASUS P4S8X-X Motherboard
ASUS P4B motherboard problems
I had the same problem a couple of times,have you tried another CPU as this points to the fact that the processor is faulting.
Jun 27, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
137 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
