Question about HP Pavilion dv9000z Notebook
I have the dv9000 bios error and broken case
Well b4 the system showed the first symptoms of the bios start up problems the joints that allow it to open and close locked up and shattered my case. so i was wondering since my warranty wont cover it how can i fix the bios problem my self or cheaply. i can still use external monitor and the only thing i can see before i lose the video is the windows recovery/ start normally options.
if ya know email me at dvishcharm@yahoo.com
Hp pavillion dv9000 after hitting power button it turns off then on off then on
In case of infinite reboot
- Restart your computer
Wait for your BIOS to display the manufacturer logo or any logo
- T
ap "F8" key immediately: you will reach a list of boot options
Select "Disable automatic restart on system failure
Press "Enter" and wait for your PC to boot.
Jul 18, 2014 | HP Pavillion Dv9000 Laptop/notebook
Turns on but will not load anything?
Assuming you mean turns on as in powers up but not loading OS...
Whenit boots press F8 or F2 for safe boot and then choose safe boot... see if the machine stops at CRCDISK.SYS. If so you will need to do a rescue of the disk if possible...reloading the OS. If that fails the DV9000 series has a known issue with NVIDIA video drivers and a google search on the two together DV9000 and NVIDIA problem will give you all kinds of info on the issue. There is a class action lawsuit in relation to the error on NVIDIA because it is a non-recoverable error. Final option is a BIOS error and to flash teh BIOS you need to be able to get into the Operating System. If the system is beeping or flashing the LED lights (power, battery, etc) during start up. This is the computers own code and dependent on the flash/beeps youwill be able to diagnose better. So listen for two short and one long, etc.
Jun 06, 2010 | HP Pavilion dv9000z Notebook
When i start my 300pl desk top system. when i
Hello my friend.That error message has nothing to do with the actual keyboard.The POST/BIOS is reading a single port bit in the system boards keyboard controller and detecting this bit as being shorted to ground. On some systems there is a keylock on the front of the case that allows you to "lock" the keyboard for security reasons. It is this lock that is being detected. On a system without a keylock, this error can be caused by one of the front panel wires being placed on the wrong pin on the system board. Or by something shorting out the keylock pin on the system board, or a hardware failure in the keyboard controller, or using the wrong version of BIOS.So make sure if your computer has a lock key/button or something on the case that locks the keyboard.Also you can load default bios settings by hitting Del while you boot if you have change anything in the bios.
Feb 08, 2010 | IBM 300PL (PC 300 PL 733) PC Desktop
Same problem, will not boot up, it has a mind of it's own.
dv2000/dv6000/dv9000 recall
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Sep 27, 2009 | HP Pavilion dv2000t Notebook
HP DV9000 won't boot up past the HP splash screen, can't enter bios or access boot menu. It just keeps starting over, freezing, then starting over again.
I think your hard drive has failed. It keeps searching for the boot sector. The boot sector is broken so the hard drive keep starting over to search for it.
Hank
Jul 28, 2009 | HP Pavilion dv9000 Motherboard
I have a hp pavilion dv9000. it had an bluetooth icon.. but now it seems to be disabled . how do i enable the bluetooth again.. everytime i try ...it shows an error... help lpz
If enabling blue tooth from the keyboard does not work anymore, then you usually need to reinstall Bluetooth drivers again.
to download drivers click on the link below, select the model, select the operative system version, then select Network Driver and reinstall bluetooth drivers from there.
HP Pavilion dv9000 Entertainment Notebook PC series - Download
If this does not solve the problem, then the bluetooth module ( a mini PCI card) may be defective. In that case an opriton could be installing an external bluetooth: TRENDnet TBW-105UB Network adapter - USB
Mar 31, 2009 | HP Pavilion dv9000t Notebook
Key board not working
It's a hardware issue,
Maybe RAM or hard drive..
Did you get it used? If so the password was set b4 you purchase it, and will not show up when you type,,,It stays hidden.
Your getting this screen because there is a hardware failure. Fix the problem and you wont need the BIOS password.
Press<esc> to enable startup message, This should give you more info on the problem.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
DV9000 issues
hey, so ir dv9000 doesnt boot to hp logo screen & restart itself,first replace the cmos battery if thisdoesnt solves ur problem, the next time u boot check whether the rj45 & the dial up port give a led flash on start or not ,if not then u may have hape board ,cpu or power problem ....which can be fixed by repair only.
Nov 30, 2007 | HP Pavilion dv9013cl Notebook
HP Pavilion dv9000z Notebook Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
