Question about Samsung HP-R5072 50 in. Plasma HDTV
60 inch phillips plasma
Hey,
I have a 60 inch Phillips and now have noticed alot of tiny red dots on the screen. Is there possibly a way to get rid of them?
  • Anonymous Jan 04, 2008
    I have a philips 50inch plasma with little red dots that appear to come and go. I have not tried anything so any suggestions will help.
  • Anonymous Mar 28, 2014
    picture shows up for 3 seconds and then goes to tv set up
  • 179 Answers
Is this a philips or a samsung? either way it sound like a diffusion problem..have the v_set and the v_scan voltages set lower bu 15vdc
if this wont help it is time for a panel
Posted on Dec 01, 2007
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
Phillips flat screen won't work
First, eliminate the possibility that the power cord, itself, is not faulty. Try another power cord from, say, your computer, or something else with the same type of power cord. This is often overlooked
Jan 07, 2009 | Insignia 42" LCD Flat-Panel HDTV
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Samsung HP-R5072 50 in. Plasma HDTV Logo
267 people viewed this question
Jerry Greenberg
Jerry Greenberg
