Question about Whirlpool Dryers
Kirkland signature by whirlpool SGDS800MQO dryer tumbles but no heat??
localwonder
  • 6784 Answers
SOURCE: Ihave a kirkland signature dryer model#seds800jqo dryer runs but
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 23, 2009
SOURCE: I have a Kirkland Signature
maybe your dryer doesnt like you...
naw im jsus playen try to clean the filter on top or somethin or maybe suttin wrong with your boiler
Posted on Oct 17, 2008
  • 1525 Answers
SOURCE: Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Posted on Jan 16, 2009
daddy1264
  • 76 Answers
SOURCE: our dryer (kirkland signature by whirlpool) quit
soundes to me like the thermal relay has opened. You have to remove the back and check all fuses....some are round some are oblong. remove both wires and test for continuity.
Posted on Sep 16, 2009
SOURCE: i have a kirkland by whirlpool gas dryer that wont
also check the 2 thermostats just before the heat duct goes into the back at the top. 1 is in the vent and the other is slightly out. you can bypass either one by moving the red wire clip to the other. if it starts working again it is likely the one you bypassed. it could also be a clogged output vent between th drum and the exhaust hose.
Posted on Feb 04, 2010
I have A whirlpool kirkland signature 4 cycle heavy duty xl capacity dryer that is not putting out the heat as it was A few days ago. I have cleaned out the vent area to the outside and still nothing. The...
did you clean out the duct that the lint filter slides down into?also remove the vent line from the back of dryer and start it,if it blows strong you still have something in the vent line,stick a leaf blower into the vent line and blow it out to the outside,if the vent is clear then you know there's a block in the dryer or you have a bad blower wheel,if the wheel is bad when you first start it you might hear the blower wheel banging around or make a sound that isn't supposed to be there,i don't know what a kirkland dryer is so next time open the door and send the model number off of the dryer.
Dec 28, 2017 | Dryers
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Our dryer (kirkland signature by whirlpool) quit heating, tumbling, and blowing. When its plugged in you can hear electricity running but nothing happens. the light stil works inside. we have removed the...
Sep 16, 2009 | Whirlpool Dryers
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer will not heat properly
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kirkland Signature dryer made by Whirlpool. It is about 2 years old. The model number is SEDS800MQ1. The dryer will not heat. All of the other functions are working, it just will not heat. It...
Oct 06, 2008 | Dryers
Dryers Logo
226 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
