Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
How to thaw a frozen ice maker? - KitchenAid Superba KSRG25FK Side by Side Refrigerator
  • 37 Answers
F your icemaker has frozen up, here's how to thaw it:
1) Unplug the refrigerator.
2) Remove the ice bin and any loose ice from the icemaker.
3) Find the fill tube, the white rubber-like hose that delivers the water into the icemaker.
4) Pull the small metal clip off the housing that holds the fill tube down (not all icemakers have this clip).
5) Warm the hose and surrounding mechanism. To do this, you can train a hair dryer on the icemaker to melt any ice blocking the mechanism.
Sop up dripping water with a rag. Be very careful when using the hair dryer near water, and do not stand in a puddle of water; there is a serious risk of electrical shock.
Also be careful not to melt the plastic parts. If you don't want to use a hair dryer, you can soak the supply tubing with hot water, using a turkey baster and catching the overflow in the empty icemaker bin. In some cases, it may be easier to remove the icemaker to thaw out the fill tube.
As a rule, refrigerators are the most dependable of all large appliances. Even so, they do fail to do their jobs adequately on occasion, and when they do, the results can be disastrous because expensive food can spoil in a hurry.
Though most problems call for a repairperson, there are a few simple repairs you can handle yourself by checking the power, controls, condenser coils, and other parts outside of your refrigerator's sealed, hermetic system.
Remember that the best way to lengthen the life of a refrigerator is to clean the condenser coils once a year—or more frequently if they get dirty.
Posted on Jun 28, 2009
5 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: I believe water flow valve to ice maker is frozen
It is going to be difficult for me to give exact directions to the fill tube but you can rely on a few photos and advice that may be better. When the fill tube begins to freeze over to the ice maker it is a sign that your water control valve for that side the ice maker side of the valve is leaking even when off it is slowly allowing water to seep into the tube between cycles of ice production. Defrosting the tube will be a good temporary fix but we need to look also at the source of the problem. I will return in a few moments with some photos. One is of a Amana model that has a split tube type. I don't think yours is the same. But it's a good view from the top and rear of the back of the freezer and back end of the ice maker. Sometimes this problem is cause by water pressure below 20PSI. Rare but possible. But most likely the weeping or seeping water control valve for your ice maker.
Posted on Sep 13, 2009
  • 87 Answers
SOURCE: Ice maker not working on Amana Side by Side refrigerator
On most Amana cabinets the water supply for the water and ice are from two solenoid valves. The water coming in goes to a double water solenoid valve splitting the incoming water so the fact there is water coming through as chilled water is not verifying that there is water supply for the ice maker. If technically minded you could locate this valve (normally at the back rhs ; compressor section) and try switching the supplies to check the solenoid valve. If you have water coming through then it may well be the icemaker module not asking for the water supply. As the simplest first step I would try defrosting the whole machine overnight and see if there is an improvement. I do know that checking the module is time expensive and would really need to be done by an engineer or alternatively replace this item. Hope this is of some help.
Posted on Aug 28, 2007
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
  • 49 Answers
SOURCE: Water line (inside freezer) is frozen shut
i always use a hair dryer just dont melt anything by getting too close. if the water line is freezing, most likely the valve that lets the water in is leaking thru just a little. this very small trickle is moving slowly enough that it has time to freeze. i would replace the valve. if it happens again you will have to put a water filter in the line because gunk in the water is making it stick part way open.
Posted on Oct 17, 2009
Whirlpool ice maker will not fill with water
1st check to see if fill tube is frozen that goes through back freezer wall to feed water to ice maker. If it is, thaw it and replace water valve. If not frozen, then you must determine if water valve or ice maker is bad. You must determine if Ice maker is sending voltage to valve. If it is, replace valve. If it's not, replace ice maker.
Sep 03, 2017 | Whirlpool Refrigerators
No water to icemaker, but through the door water is working. Ice maker itself is ok.
This is most likely cause because some part of the ice maker/distribution mechanism is broken. If at all possible, remove everything from the fridge and freezer and allow the freezer to thaw. If that is not possible, you could try and remove just the ice maker to thaw it or try and thaw it while it is still in the freezer. I hope this helps and have a nice day!
May 04, 2011 | LG LFX21980ST Stainless Steel Bottom...
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker waterline frozen
Occasionally these freeze up on many brands. Usually if the ice maker is not used much. There is a rubber tube that deposits water into the ice maker unit, Thaw it by warming it with your fingers. You can carefully use a hair dryer as well
Jan 15, 2010 | GE Refrigerators
Ice maker appears frozen.. last pieces of ice to come out were in frozen clumps. Now not doing anything
Need to defrost the freezer. The ice-maker water path sometimes freezes so it must be thawed out.
Jul 15, 2009 | Refrigerators
Frozen water in ice tray
You do need to thaw the ice maker out completely. I always remove it but that may be more than you are up to. You can also try a hair dryer on it to thaw it out.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 26, 2018 | Whirlpool GS6NBEXRB Side by Side...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker water line appears to be frozen on gd5sha. ice maker won't function.
thaw the whole refrigerator for a whole day to thaw the ice inside the water line. it will reset also the timing of the ice maker.
Jul 05, 2008 | Whirlpool Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Ice maker doesn't work
When you say you are getting water do you mean you are getting water in the ice maker tray? If so then unfortunately you will need to replace the ice maker. If not getting water to the ice maker then make sure the fill tube to the ice maker isn't frozen shut. If so, thaw it out and see what happens. If it isn't frozen shut then replace the ice maker. New ge ice makers, when installed, will not cycle until the ice maker gets below freezing so you will have to wait once it is installed.
Oct 07, 2007 | GE Profile PSI23NCR Side by Side...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
2,802 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
