Question about Pioneer KEH-P2030 Cassette Player
Time change on Pioneer car radio
My brother does not have the manual for his Pioneer radio that was installed in his pickup about 3 years ago. He cannot figure out how to change the time. Can you help?
  • 20 more comments
  • Anonymous Nov 12, 2007
    how do i set my clock on my pioneer radio.. deh-3900mp
  • Anonymous Nov 18, 2007
    need manual cant set time
  • IFFYMAN Dec 08, 2007
    I NEED TO SET MY CLOCK
  • ryanh6291 Dec 12, 2007
    i need help remembering how to change the time on the headunit.
  • Tom Fitzsimmons
    Tom Fitzsimmons Dec 18, 2007
    I don't have the manual either. The model is a Pioneer Premier DEH-P330 Super Tuner III CD AM/FM receiver for playing a single CD. I hope someone will post the method of changing the displayed time on the clock.
  • IYQYQR Dec 22, 2007
    So far, I have held down every combination of buttons that I could think of, in pairs, and threes, holding for 4+ seconds. I've turned the dial and punched the buttons. I've run out of ideas.
  • Chrissy Hancock
    Chrissy Hancock Dec 22, 2007
    I've pressed the clock button and all the up and down arrows at different times.
  • ccan051 Dec 27, 2007
    DEH-1300 Can't figure out how to set the clock. I have tried pushing all buttons with everything on and/or off!
  • Anonymous Dec 29, 2007
    i bought a new car for myself for christmas and it already had a pioneer cd player installed, but the time isn't right. how do i set it?
  • Anonymous Jan 03, 2008
    can t set clock on pioneer deh 2700
  • alll Jan 03, 2008
    can not set clock on super tuner 3
  • Anonymous Jan 08, 2008
    need help
  • cortneys Jan 09, 2008
    i can not figure out how to set the clock on this?
  • Sawdust Jan 27, 2008
    I took the car back to Best Buy and guess what? The emergency brake had to be on to change the time!!! Thanks for all of your responses
  • Anonymous Feb 10, 2008
    dont no how set clock
  • vidu71 Feb 11, 2008
    I have pioneer super tuner 3 cd player please let me know how to change the time and setup the clock
  • Anonymous Mar 30, 2008
    cant set the time on my pioneer radio.
  • Anonymous Apr 01, 2008
    Changing the time on my Pioneer DEH-2700 Super Tuner. How does this work?
    can't set time
  • buster13 Apr 14, 2008
    how do i change the time on my raido mosfet50 wx4
    my address kes13@charter.net
  • Anonymous May 21, 2008
    I have a deh-17 and I cannot set the time does anyone have a clue thank you
  • DaddysSugar Mar 07, 2009
    We can't even turn the radio off, just the volume down?
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Posted on Jan 14, 2008
The manual for my Pioneer radio (DEH-2000MP) said to push the FUNCTION button but that did nothing. I needed to push the SOURCE/VOLUME button and hold it in until the hour started blinking, release the SOURCE button and then use the up and down arrows to change the hour. Use the right arrow to change the minutes (they'll start blinking.)
Posted on Nov 11, 2009
With radio off hit "Clock" key (should display time). Hold "Function (F)" key 4 seconds. Display should light up. Use "up" or "down" arrow to change time. Use "left" or "right" keys to switch from hours to minutes. Hit "Function (F)" key to exit.
If this doesn't work you might want to try setting your emergency brake as someone else has suggested.
Posted on Apr 28, 2008
Try turning the unit off then hold the off button till the clock flashes then use the remote function button to select between hour and minutes then hit the off button again shuold be good.
Posted on Sep 12, 2009
OK here's your fix...  go to http://www.pioneerelectronics.com/PUSA/Support. In the search window at the upper right of the page, search for your model (i.e. DEH 2700). That will lead you to a general page for your model. Click on the Documents tab on the page. There's your manual. RTFM.
Posted on Feb 05, 2008
Hold the audio button till the time shows; press the function button and the clock ill start blinking. Use the right - left arrows to chose hour or minutes. Use the up and down buttons to set the hours or minutes. Then press function again to go back to normal setting! Dang that was really hard to learn though!
Posted on Apr 18, 2008
Push and hold the volume dial, use the L-R keys to change Hour to minutes, Up-Down for numbers.
Posted on Feb 14, 2011
  • 709 Answers
No way to know or get help unless you post the model number. Most of the time you need to turn the radio off and press set, mode or Prog, then push another button somewhere to get the hours or minutes to change.
Posted on Nov 07, 2007
How do I change the clock?
Posted on Mar 10, 2009
Have two pioneer radios in older hondas. Try this for the Pioneer keh-2600. Hold down clock button. Then press selection "1" for the hour until you get hour. Do the same for minutes, except press selection "2" button. Other than that, go to pioneer.com website for exact model. Thats where i got this idea from.
Posted on May 24, 2008
    Scholar:
  • 25 Answers
Instructions
    • 1 Turn the ignition key to On or Accessory. Pull up the emergency brake.
    • 2 Press Source or Power to turn the Pioneer car stereo off.
    • 3 Press the Clock button to display the time.
    • 4 Press and hold the Function or Audio button for 3-4 seconds. The display will come on, and the hour should flash.
    • 5 Use the Up or Down buttons to change the hour setting on the stereo.
    • 6 Press the Left or Right keys to get to the minutes. When the minutes start to flash, press the Up or Down keys to set the clock to the correct minutes.
    • 7 Press the Function or Audio button again to exit.
Posted on May 19, 2011
It was the audio button on mine, NOT the function button, so solution #4 worked great for me.
Posted on Aug 22, 2010
I can't believe this worked. My son has a pioneer cd player in his truck. No one has ever been able to figure out how to change the time. I googled "how to change the time on my cd player clock" and this was the first site I clicked on to find information. I went out to the truck where he was just ready to pull away. We followed the instructions and it worked perfectly. Turned off the player, hit the time button, and then the audio button (there was no function button) and got the flashing hour number, changed that, moved over to the minute button and changed that, and hit "time" again, and it was working!
Thanks everyone for all your help.
Posted on Aug 21, 2008
It' not the audio button, it's the func button
Posted on Mar 08, 2008
Try turning the ignition key to On or Accessory. Turn the radio off. Press and hold the Function button for 3 seconds, and the hour should flash. Use the Up/Down keys to change the hour. Then press the Left/Right keys to get to minutes and when that flashes use the Up/Down keys to change minutes. Then press Function again to exit. Hope this works.
Posted on Dec 19, 2007
3 Suggested Answers
SOURCE:
mixmaster
  • 626 Answers
SOURCE: time change on Pioneer car radio
Whats the model number?
Posted on Nov 21, 2007
  • 102 Answers
With power OFF, press and hold the FUNC (or CLK) button until the date and time are displayed. Use the up/down/left/right control to set numbers and change positions....when happy with date and time turn unit ON..should be good to go.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
How do i install a pioneer deh-1550 car radio
The installation manual is here
Pioneer DEH 1550 Installation Manual
PIONEER DEH-1550 INSTALLATION MANUAL Pdf Download.
https://www.manualslib.com > ... > Car Stereo System > DEH-1550 XU
View and Download Pioneer DEH-1550 installation manual online. DEH-1550; DEH-1550B. DEH-1550 Car Stereo System pdf manual download. Also for: Deh-1550b, Deh-3450, Deh-2450f.
[PDF]DEH-1550UB DEH-1550UBG - Pioneer
www.pioneer-latin.com/.../operating%20manual%20(deh-1550ub)-eng-esp-por.pdf ???? ???????? CD ?? ????? RDS. ?????? ?????? CD RDS. Espa?ol. DEH-1550UB. DEH-1550UBG. Portugues (B). Owner's Manual. Manual de instrucciones i ... PIONEER Service Station. Press to recall preset stations. Press to select the next/pre- vious folder. AUX input jack. (3.5 mm stereo jack). 6 Disc loading slot 3. O USB ...
How To - Understanding Pioneer Wire Harness Color Codes for DEH ...
? 6:05
https://www.youtube.com/watch?v=kR2MO2kwFug Nov 14, 2016 - Uploaded by pioneerelectronics
Learn about the Wire Harness Color Codes for Pioneer in dash receivers that do not have video screens. DEH ...
How to restore and reset your Pioneer DEH radio - YouTube
? 1:20
https://www.youtube.com/watch?v=_QyuVanWfLA Jul 26, 2016 - Uploaded by Five Star Car Stereo
in this video we show you how to restore your radio into factory default settings. ... to restore and reset your ...
Mar 24, 2018 | Pioneer Car Audio & Video
Changed car battery and now Pioneer DEH-P7700MP doesn't work
check behind radio for inline fuses . useually on red and yellow wire's . most likly blew one . or fried radio all together . most likely just fuse , thats why they are there
May 24, 2009 | Pioneer DEH-P7700MP CD Player
1997 XE pickup - clutch frequently "groans"
hi
Its your clutch release bearing.
change the clutch
3 piece clutch kit. (pressure plate + clutch plate and release bearing)
your problem will be fixed.
hope that helps
Jul 19, 2017 | 1997 Nissan Pickup
I need to install my cd player
yeah i can help you out but i need to know year, make, and model and if the harness from the factory radio is intact or cut from the vehicle.
Mar 29, 2009 | Pioneer DEH-445
Mar 10, 2009 | Pioneer DEH-1600 CD Player
Can't change time on my in-dash Pioneer model #1300, CD, Radio
turn off the radio then press the clock button. now pressing for about three seconds the function button then the clock should appear on the screen.
Nov 01, 2008 | Pioneer DEH-1300 CD Player
Pioneer super tuner 3
For most Pioneer single CD players, you can set the clock using the following steps:
1. Press and hold the SOURCE button until the unit turns off.
2.Press and hold the FUNCTION button, until display pops up, then release.
(If you do not have a FUNCTION button, then push the AUDIO button)
3. Press the FUNCTION button again until the clock shows on the display.
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6.Press the UP and DOWN to adjust minutes.
7. When complete, press the SOURCE button to exit.
  • 1 year ago
Apr 29, 2008 | Car Audio & Video
Changing the time
Here's a link to the manual Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Dec 25, 2007 | Pioneer DEH-1500 CD Player
AVIC-N2 dies after year and a half
Contact Tech Support for Pioneer. They have a call back on the Flex Cable which is the source of all your problems. It took 2-3 weeks for the repairs. Although, now I have a problem with the screen rolling out.
Apr 03, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer KEH-P2030 Cassette Player Logo
22,732 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
